rear diff issues - JeepForum.com
post #1 of 8 Old 09-21-2012, 03:55 PM Thread Starter
j888dth
2003 KJ Liberty
rear diff issues
Hi just purchased 2003 kj (Liberty) 2.8 diesel (UK spec) and trying to find out about it . I think the rear Diff is what seems to known as standard (please see attached) but what is standard ? does it have limited slip? does? it have any form of lock. I have read somewhere on here all builds details can be obtained from Jeep web site but it does not seem to be available to us over here in The UK. So any one got any ideas how I can decide whats what. The problem I am looking at is I get what feels like wheel spin when setting of on right hand turns its ok on left hand or straight.
j888dth is offline
post #2 of 8 Old 09-21-2012, 07:08 PM
tjkj2002
2002 KJ Liberty
Well you have a Chrysler 8.25 rear diff.If the sticker on the axle tube is still there it will say open or traclok or you can jack up the rear end,both wheels off the ground, while the KJ is in "Park",try to spin one rear wheel,if it spins and the otherside spins the other direction your open,if you can not spin it you have the trashlok(OEM LSD).
tjkj2002 is offline
post #3 of 8 Old 09-22-2012, 04:38 AM
Billwill
2002 KJ Liberty
Well that picture looks exactly like my 4.10 Traclok on my 2002 2.5 Export CRD....minus the rust....we do not have ice and salt on the roads here in SA!
The label on mine is located at the end of the axle on the right side.
I recently replaced the oil in mine....first the LSD additive from Mopar then 75W90 oil.
Obviously before putting the oil in I had to use RTV sealant on the cover....I used Permatex Ultra Grey RTV sealant...no problems with leaking.
@the OP....that slipping problem does sound like it could be a Tracloc in need of some Mopar LSD fluid....if it is a Tracloc then you could try syringe some fluid out and replace with LSD additive but rather remove the cover and replace the oil and additive at the same time as you do not know if the lubricant has ever been replaced.
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
post #4 of 8 Old 09-23-2012, 01:13 AM Thread Starter
j888dth
2003 KJ Liberty
Thanks Guys
I have had both wheels up and with transmition in N all brakes removed i can turn the hubs but need crow bar across studs as i cannot get enough leverage without. As i have no idea if the diff has had lubricant changed I think it bust if I get some and some of this LSD additive which is one of the reason for trying to find out what diff i have as see little point adding LSD additive if my diff is not a LSD.
j888dth is offline
post #5 of 8 Old 09-23-2012, 01:36 AM
Billwill
2002 KJ Liberty
Seeing as you have it on stands and the brakes off I would suggest you open up the diff....remove the cover and drain the oil out in the process.
Then have a good look inside and see if there is any wear or damage.
I will post up a picture of what the Tracloc looks like inside.....if that is what you do have then I will post some more advice on what to do.
Or you can download the service manual yourself on the following link....choose the 2003 Jeep KJ Service Manual......about 63 Mb ....it has everything you need to know about fixing your KJ plus has complete circuit diagrams.
http://www.colorado4wheel.com/manuals/Jeep/KJ
Billwill is offline
post #6 of 8 Old 09-23-2012, 12:55 PM Thread Starter
j888dth
2003 KJ Liberty
thanks if you could pop inside view that would be good. I have downloaded all manuals which cover just about every option apart from how to decide which oprtion one has.
j888dth is offline
post #7 of 8 Old 09-24-2012, 08:40 AM
Billwill
2002 KJ Liberty
Sorry, I thought the Service Manual had a good picture of what the inside of a Traclok diff looks like but there is only a small diagram that shows the position of the clutches.
I would suggest you replace the oil in any case which means removing the diff cover. Then have a look for the clutches with reference to the diagrams in the Service Manual....this will tell you if this is a Trackloc or not.
Then use a good RTV Silicone to seal the cover, allow the bead of RTV to semi-harden while lightly tightening the bolts then tighten the bolts correctly according to the instructions on your particular brand of RTV.
Then if you have determined that you do have a Traclock, pour in one small container of Mopar Friction Modifier and then 2 litres of oil....I used Castrol 75W90 after doing a lot of reading up on the subject.
The Service manual then states...for a Trackloc....that you must get the Jeep to do 8 or ten slow figure 8 turns to get the oil spread properly in the clutches.
Billwill is offline
post #8 of 8 Old 09-24-2012, 11:04 AM Thread Starter
j888dth
2003 KJ Liberty
Thanks Billwill
What I need is one large car park to do figure 8 turns (used to have scalextric with the figure 8 as a lad). wonder how dealers do it as cannot imagine many have an area large enough to do it! hope police don't see me cus they will think i'm mad.
j888dth is offline
locked rear diff? jbjmed KJ Liberty Forum 6 04-28-2012 10:54 PM
'02 with front diff issues after 3" spacer install Mullins_J KJ Liberty Forum 3 12-22-2009 05:55 AM
Rear Diff LSD or not? johnnyhotshoe KJ Liberty Forum 4 11-09-2009 06:04 PM
How do I tell which rear Diff I have JMMKJ KJ Liberty Forum 5 11-24-2007 07:18 PM
How much for a new rear diff? Therou KJ Liberty Forum 3 05-03-2007 06:50 PM
