read before you assume....tires/rim size help - JeepForum.com
post #1 of 6 Old 01-04-2008, 11:38 AM Thread Starter
CMax26az
2007 KJ Liberty
i have been searchng for a while through the forums and i cant find the answer to this question:
Generally speaking, what is a better rim size for offroading? 15" or 16" ?
can a 15" rim be mounted on a KJ?
will it clear the front calipers?
will there be other clearance issues for turning radious?
Is there an advantage for 15" vs 16"?
I'm asking this because i want to get a wheel/tire combo for offroading and there are alot more tire options in the 15" range. Right now i have no plans for a lift but i may in a year or so.
my stock tire is 235/70/16, this equals to the inches sytem as a 29x9.5/16. but i cant find anyting close to 29x9.5 in a 16" rim. they do however have them in 15" rim. even if i stay with the metric tire sizes, the closest i can find is 225/75R16 (a more narrow tread) or 245/75R16 (taller and wider, will i have a clearance issue?).
comments? suggestions? oppinions?
Craig + Elizabeth
ASE Certified Professional AKA: MacGyver
07' KJ, 2.5" lift, skids + hooks, Moab 16's and MTR's, safari rack, 4 PIAA's, AZ pinstripes,
CMax26az is offline
post #2 of 6 Old 01-04-2008, 12:46 PM
Parky
Parky's Avatar
It varies on the rim. The minimum for a 15" would need less back spacing, but each rim is different. I think I saw (about a year ago) someone with Krager soft 8s in a 15" rim but they had 3.75 or 4" back spacing to get over the caliper issue. Remember, if you do go with less back spacing, the pivot point of the tire changes and you may get rubbing on the pinch weld or the front bumper.
Colorado Jeep Member #12
Happy Jeeper
Parky is offline
post #3 of 6 Old 01-04-2008, 04:01 PM
phxtoad
2002 KJ Liberty
Tires
Try this - this chart should answer some questions for ya...
http://www.jeepkj.com/forums/viewtopic.php?t=1130
It's really rare hearing anyone running 15's...
Pounding down the pinch welds is a great way to exercise!
Todd
Phxtoad
'02 KJ, modified to get there and back
'95 YJ, 2.5" RE, 32's, open
phxtoad is offline
post #4 of 6 Old 01-04-2008, 04:14 PM Thread Starter
CMax26az
2007 KJ Liberty
im going with either:
Firestone Destination M/T
225/75R16
245/75R16
or
Kumho Road Venture M/T
225/75QR16
245/75QR16
neither make a 70 series in 16"...
so the question remains, the 225's or the 245's ?
Craig + Elizabeth
CMax26az is offline
post #5 of 6 Old 01-04-2008, 04:20 PM
P NUT
You will have much more choices in 245's (IIRC). The problem is, will you experience any rubbing? That I don't know. If either size will work, I'd go with the 245's. But I'm guessing that the 245's will work without too much problems--maybe a slight rub at full lock and compression. And I've heard better reviews with Kumho's than Firestone's.
Also, do you need an M/T? I'd look into Michelin LTX A/T or Bridgestone REVO's, too. My friend with the LTX A/T has over 90k on them and still has some life left. Amazing wear on those tires. And he's gone to Moab several times, too on the same tires.
P NUT is offline
post #6 of 6 Old 01-04-2008, 05:03 PM Thread Starter
CMax26az
2007 KJ Liberty
I'm going to keep my stock rims/tires for daily driving and swap in the mudders for weekend fun as needed, so yea, i want and M/T's
tire comparason
Craig + Elizabeth
CMax26az is offline
Please Read Gramps KJ Liberty Forum 1 06-14-2009 12:49 PM
Lifting KJ for wife... what size tires?? cjyj85 KJ Liberty Forum 4 12-21-2007 10:29 AM
different size tires on liberty sexyliberty KJ Liberty Forum 8 06-10-2005 06:35 PM
Tires Size need suggestions... naguabo KJ Liberty Forum 18 10-11-2004 02:30 PM
What size tires should I run BIGCRAZYBELL KJ Liberty Forum 3 10-30-2003 09:23 PM
