radiator replacement 05 kj sport 4x4 auto with a/c - JeepForum.com
post #1 of 6 Old 07-19-2013, 06:15 PM Thread Starter
05kjsport
2005 KJ Liberty
libby has 128,000 miles radiator leaking from drivers side down along the side of the plastic outer housing. if anyone can give me any tips tricks to this job i appreciate it. going to get a oem radiator from local jeep dealer tomorrow got a buddy thats a master tech there hopefully i wont get gouged on the price, seems like a pretty straight forward job but if anyone has run into any snags please let me know.
05kjsport is offline
post #2 of 6 Old 07-19-2013, 06:48 PM
tjkj2002
2002 KJ Liberty
Do you have HD cooling(IE the mechanical fan)? If so you will need some special tool to remove/install that but if not it's pretty straight forward though I'd remove the battery tray as it has a piece that hangs out(used to mount the PS pump for those KJ's with the 2.4 gas engine) that makes it fun trying to get the old radiator out and new one in.You can cut that piece off if you wish so you don't have to remove the whole battery tray.
tjkj2002 is offline
post #3 of 6 Old 07-19-2013, 07:05 PM Thread Starter
05kjsport
2005 KJ Liberty
it has the 3.7 with the electric fan, is there a way to fill the radiator from the top? i was told to remove the hex bolt from the top radiator hose housing to fill the new radiator so there is no air in the system, fill the new radiator completely then fill the expansion tank to full cold. i have not taken the crossmember off on top of the radiator yet, is there a fill on top?
post #4 of 6 Old 07-19-2013, 07:22 PM
tommudd
2004 KJ Liberty
No fill on top
never done it the way someone told you to, replaced mine once , buddy with an 03 has done his a few times ( cheap radiators) and always just filled from the reservoir
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
tommudd is offline
post #5 of 6 Old 07-19-2013, 08:16 PM Thread Starter
05kjsport
2005 KJ Liberty
so the question at hand is do you fill the system from the expansion tank? or do you fill the radiator from the top hose port until full then fill the tank to full cold? and is it necessary to remove the bleeder screw when filling the system?
post #6 of 6 Old 07-19-2013, 09:16 PM
tjkj2002
2002 KJ Liberty
You can do it eitherway,both work and I've done it both ways and either works.
Now if you replace the t-stat you will want to fill through tha bleed screw to fill the engine also to make "burping" the system much easier,not required if just replacing the radiator.
tjkj2002 is offline
