Quick lift and tire question - JeepForum.com
post #1 of 5 Old 08-01-2013, 12:06 PM Thread Starter
604Mickey
2002 KJ Liberty
I'm looking at BFG A/T's 245/75/16 will this fit right with a Franken Lift and the pinch weld pounded out? Will there be rubbing?
604Mickey is offline
post #2 of 5 Old 08-01-2013, 01:09 PM
95BadBoy
You should be good to go with that (31") tire size using factory 16" wheel offset depth.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #3 of 5 Old 08-01-2013, 03:16 PM
tommudd
2004 KJ Liberty
Depends on wheels being used as well
not knowing that can not say for sure
If stock OK, or if 16X7 with stock backspacing or 4 inches of backspacing then you're good
You'll lose some power and mileage but part of lifting etc
MUDD'S MOTORSPORTS
04 KJ JBA 4 INCH COILOVER LIFT
03 KJ JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #4 of 5 Old 08-01-2013, 10:16 PM
Luke09
2005 KJ Liberty
With stock wheels you'll rub on the sway bar.... if you add adapters it (rubbing) will move to the wheel well liner (bottom-front), minor trimming solves that however.
2005 Liberty Renegade - Dark Khaki
Frankenlift IIP, Mobil1 Synth.& Filter, PIAA Extreme White, Amsoil EA Filter, Spidertrax 1.25, 245/75/16 Duratracs
Luke09 is offline
post #5 of 5 Old 08-02-2013, 02:19 AM Thread Starter
604Mickey
2002 KJ Liberty
Thanks for the info,helps a lot
