problems starting - JeepForum.com
post #1 of 5 Old 04-06-2014, 06:29 AM Thread Starter
jpfix
problems starting
My 2005 Jeep Liberty has had some occasional problems starting since I purchased it in 2009. The vast majority of the time it starts up just fine, but every once in awhile, it just doesn't quite want to turn over all the way. It'll be almost there, but it just doesn't want to start. It typically happens when the car is warm (i.e. has been driven for 30-45 minutes and then left to sit for 20 minutes), and when I turn the key it just doesn't start (it WANTS to, it just doesn't quite get there). Usually, if I try a few times and turn the key extra hard and maybe give it some extra gas, it will start up. Every time I have taken it to a mechanic, I've mentioned this problem, and they'll try to figure out the issue, but they are never able to get it act up. My gas mileage has taken a major nosedive over the last few months as well. I'm not sure if they're related issues, but figured I should mention it. Any ideas?
91 YJ Runs 79 CJ5 waiting for winter
YJ - one step away from a CJ = lots of interchangeable parts.
TJ - one step away from a JK = sudden urge to go to the mall
jpfix is offline
post #2 of 5 Old 04-06-2014, 08:06 AM
streetglideok
2005 KJ Liberty
First suggestion, don't make multiple posts about it,lol. How old are your spark plugs? Less than 30k, copper core plugs gapped to OE spec? What kind of fuel do you use? Not E85 right? Lastly I would check fuel pressure. If it is running below spec, heat soak conditions can make a vapor lock condition.
streetglideok is offline
post #3 of 5 Old 04-08-2014, 03:15 AM
Billwill
2002 KJ Liberty
If it does not want to turn over all the way sometimes I would suggest the battery needs checking, the battery connections need to be clean and tight, the negative battery lead to chassis must be clean and tight and the grounding cable from engine to chassis must be clean and tight on both ends.
Also swap out the Starter Relay with an identical one next to it.
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
post #4 of 5 Old 04-08-2014, 07:48 AM
Bilge
I'll get back to you after I get back from the mall.
Currently Own: '99 WJ - '02 KJ - '05 WK - '08 JK
Bilge is offline
post #5 of 5 Old 04-08-2014, 04:44 PM
JeepOwner33
2003 KJ Liberty
Sounds like what I have been going through.
Here is a topic I started on this a few days ago with a lot of good responces.
http://www.jeepforum.com/forum/f28/h...-help-2286929/
JeepOwner33 is offline
