#1 | |
Power Windows Seized
IF YOU HAVE AN 06 KJ AND ANY OF THE WINDOWS ARE INOP THIS IS A NEW RRT. NOT A RECALL BUT A RESPONCE TRANSMITTAL FOR DEALERS.
September 11, 2006 TO: ALL JEEP DEALERS FROM: GLOBAL SERVICE SUBJECT: RAPID RESPONSE TRANSMITTAL SERVICE ACTION # 06-038 Power Window Motor(s) Seized INVOLVED VEHICLES: 2006 (KJ) Liberty NOTE: The VIN List is available on DealerCONNECT for all affected dealers. The VIN List has been inserted in the Service Tab under Rapid Response Transmittals. The dealers receiving the Rapid Response Transmittal Service Action are the “Ship To” dealers and the VIN’s listed are specific to their dealership. SYMPTOM/CONDITION: A number of vehicles may have been shipped with a seized power window motor(s) DIAGNOSIS: 1. Place the ignition key in run position, DO NOT start the engine. 2. Cycle each window individually from full up to full Down; continue to energize the regulator for 2 seconds after impacting the Down stop. 3. Return window to full up position. 4. Repeat steps 2 and 3, three times. 5. If all windows cycle normally, Diagnosis is complete and no further action is required, otherwise continue to step 6. 6. Leave the key in run position. Verify all accessories are off i.e., radio, lights etc. 7. Place an inductive amp meter over the positive battery cable. Record amperage draw. 8. Cycle the window that did not cycle normally and measure amperage draw. 9. Subtract measured amperage draw in step 8 from the amperage draw measured in step 7. If the difference exceeds 6.5 amps then perform the Repair Procedure. If the difference is less than 6.5 amps, motor operation is not the issue and this Service Action does not apply. 10. Repeat steps 8 and 9 for all windows that did not cycle normally. PARTS REQUIRED: (AR) 1 04589265AA Regulator, Window Left Front (AR) 1 04589266AA Regulator, Window Right Rear (AR) 1 04589267AA Regulator, Window Left Rear (AR) 1 04589268AA Regulator, Window Right Front
[FONT="System"]06 JS 2.7L, 97 NS 3.8L, Yamaha Banshee's. Shop Foreman @ Chrysler Jeep Dodge Dealer.[/FONT] |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
