Power window not going UP - JeepForum.com
post #1 of 5 Old 10-17-2010, 05:38 PM Thread Starter
gcotterl
2004 KJ Liberty
The glass on the right front window has intermittently stopped going UP when I use the switch on the console. (If I continue fiddling with the switch, the glass will/may eventually go up).
Is this a problem with the switch, the window regulator and/or other mechanism?
gcotterl is offline
post #2 of 5 Old 10-18-2010, 10:31 AM
95BadBoy
Seeing as it eventually goes up after multiple tries with the toggle, sounds more like the switch.
It always helps if you fill out your Jeeps profile, so those who may answer have a better idea what your working with.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #3 of 5 Old 10-18-2010, 11:05 AM Thread Starter
gcotterl
2004 KJ Liberty
Power window not going up
In 1977, I bought a new Toyota FJ-40 Landcruiser which was built like a tank. But the gas mileage sucked so I had the smog-equipment removed and installed headers and a 4-barrel carburetor. This only marginally improved the power and the mileage.
In 1983, I bought a new Jeep CJ-7. Because I had to make the FJ-40 California smog-legal, I found a shop that "claimed" that they could locate and install the smog equipment. Two years later, the shop "gave up".
Since my FJ-40 had been sitting in the shop's back-lot (subjected to the weather and vandalism), I ended up selling the FJ-40 for $500 salvage).
I kept the CJ-7 for 18 YEARS and made NO modifications to it. I drove it 99 44/100% of the time back-and-forth to work and 56/100% off-roading (in Death Valley, Canyonlands, Glamis and other places). It was an OK vehicle but it had a lot of problems with the Pulse-Air smog system and with the transmission.
In 2004, I sold the CJ-7 for $7,000 (!) and bought the Jeep Liberty. I've made NO modifications to it. Except for regular maintenance (fluid and filter changes and one tune-up, etc), it's been a good vehicle. It it hasn't been off-road except for maybe 5 miles.
gcotterl is offline
post #4 of 5 Old 10-18-2010, 08:30 PM
95BadBoy
Hope things find there way to functioning, and it's only a switch and not wireing. Wish I had that FJ40.
95BadBoy is offline
post #5 of 5 Old 10-19-2010, 07:19 AM Thread Starter
gcotterl
2004 KJ Liberty
Where I can get a new switch for the front-right (passenger) power window? (The switch goes in the center console).
gcotterl is offline
Power Window Problems dagooaz KJ Liberty Forum 15 04-01-2015 10:53 AM
Just another power window problem.. 4xjeep KJ Liberty Forum 0 03-21-2010 05:44 PM
power window anomoly mollydodger KJ Liberty Forum 3 08-25-2009 04:00 PM
Power Window not working rileycentral KJ Liberty Forum 5 06-03-2008 12:25 AM
power window problems on '06 chadlyt KJ Liberty Forum 8 05-29-2008 12:30 PM
