Power Steering Hose - JeepForum.com
post #1 of 13 Old 05-08-2014, 08:35 PM Thread Starter
02jeepliberty
Power Steering Hose
My high-pressure power steering hose is leaking. What is a good decent brand to replace it with? Or should I just replace it with another OEM hose?
02jeepliberty is offline
post #2 of 13 Old 05-09-2014, 11:35 AM Thread Starter
02jeepliberty
Someone has to know, anybody???
post #3 of 13 Old 05-09-2014, 07:53 PM
TwoBobsKJ
TwoBobsKJ's Avatar
2003 KJ Liberty
There are hose kits available through RockAuto.com as well at the various auto parts stores. I would choose OEM if I had to replace mine just for the peace of mind that it will hold up for the long haul.
My 2 cents
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, ARB Bull Bar, Smittybilt XRC 9500lb Winch, 4X Guard Trans skid, Skid Row Engine skid, Factory T-case & Tank skids, Custom BoulderBars, JBA Front Coilovers, OME 948 rear springs, Bilstein rear shocks, JBA A-Arms, Moabs with Goodyear Duratracs 265/70-16
TwoBobsKJ is offline
post #4 of 13 Old 05-10-2014, 07:02 AM
02blue
2002 KJ Liberty
"Hey, ya never know til you try." Kurt Russell-Big Trouble in Little China
02blue is offline
post #5 of 13 Old 05-11-2014, 07:50 AM
AVR2
I've got the Edelmann hose from RockAuto in mine. Fraction of the cost of OEM, it looked identical when I compared them side-by-side, and it's been holding up fine for 3 years now.
AVR2 is offline
post #6 of 13 Old 05-11-2014, 02:38 PM Thread Starter
02jeepliberty
Did it come with any type of warranty?
post #7 of 13 Old 05-11-2014, 03:15 PM
5-90
5-90's Avatar
1988 XJ Cherokee
I've been using Edelmann for years. I don't recall their warranty - but the best warranty is the one you don't need, and I've never needed Edelmann's.
Nota Bene - Make sure you use a flare nut wrench to remove and install the hose! It will be a metric size - probably 16m/m or 18m/m - but the flare nuts are nowhere near as hard as a regular hex nut, and you are likely to round the thing off if you use a regular wrench on it.
I usually coat the threads with never-seez, tighten it down finger tight, then add 1/4-1/3 turn after with a wrench (torque angle is workable regardless of lubricant used, since it will always give the same preload.) Check it after a day's service, tighten an additional 1/6-turn if necessary. You should not need to do more than that.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #8 of 13 Old 05-11-2014, 09:59 PM Thread Starter
02jeepliberty
Originally Posted by 5-90
I've been using Edelmann for years. I don't recall their warranty - but the best warranty is the one you don't need, and I've never needed Edelmann's. Nota Bene - Make sure you use a flare nut wrench to remove and install the hose! It will be a metric size - probably 16m/m or 18m/m - but the flare nuts are nowhere near as hard as a regular hex nut, and you are likely to round the thing off if you use a regular wrench on it. I usually coat the threads with never-seez, tighten it down finger tight, then add 1/4-1/3 turn after with a wrench (torque angle is workable regardless of lubricant used, since it will always give the same preload.) Check it after a day's service, tighten an additional 1/6-turn if necessary. You should not need to do more than that.
Ok, so I have found some Edelmann PS hoses on eBay. They don't look they exact same as the OEM ones I have found. Could it just be a generic picture Edelmann is using? The first picture is the OEM Mopar one, second is Edelmann. Let me know what you think, thanks for the help!
post #9 of 13 Old 05-11-2014, 11:11 PM
AVR2
Yes, Edelmann is using a generic photo of the 2004+ hose which doesn't have the integrated pressure switch. If you look up RockAuto's listings for the 2002-03 KJ hose, it specifically says "with switch port".
RockAuto's info page about the Edelmann hose says there's a 12 month warranty, but like 5-90 says, the best warranty is the one you never have to use. I also have an Edelmann PS hose in my 1993 ZJ, and that's holding up equally well (and again cost a fraction of the OEM price).
AVR2 is offline
post #10 of 13 Old 05-12-2014, 03:25 PM Thread Starter
02jeepliberty
Yes, Edelmann is using a generic photo of the 2004+ hose which doesn't have the integrated pressure switch. If you look up RockAuto's listings for the 2002-03 KJ hose, it specifically says "with switch port". RockAuto's info page about the Edelmann hose says there's a 12 month warranty, but like 5-90 says, the best warranty is the one you never have to use. I also have an Edelmann PS hose in my 1993 ZJ, and that's holding up equally well (and again cost a fraction of the OEM price).
which is the one I need? I don't know the difference between the first two...
post #11 of 13 Old 05-12-2014, 10:03 PM
tjkj2002
2002 KJ Liberty
Either one,same hose just different manufacturers.
tjkj2002 is offline
post #12 of 13 Old 05-13-2014, 07:07 AM Thread Starter
02jeepliberty
Which is the better manufacture? The Edelmann?
post #13 of 13 Old 05-13-2014, 08:36 AM
tjkj2002
2002 KJ Liberty
I'd trust the Gates name before any others.
tjkj2002 is offline
