Power Steering clicking noise when the steering wheel is turned fully left or right. - JeepForum.com
post #1 of 5 Old 08-13-2012, 11:12 PM Thread Starter
extranrg
2006 KJ Liberty
Usually, when I turn the wheel to the left or right limit, I can hear the pump strain, but that is the extent of the noise. Lately, if the steering wheel is turned to its limits either left or right, I get a continuous clicking noise until I back the wheel off slightly. This has started in the last week. I haven't changed anything or hit anything. Any ideas what might be going on and what I should look at replacing? Thanks in advance for the help!
extranrg is offline
post #2 of 5 Old 08-17-2012, 08:33 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Hopefully someone will answer this for you. I don't know what is going on here. I'm not very technical. I'm going to post steering system diagnosis information in the next post - maybe that will help somebody think of something it could be.
JeepCares is online now
post #3 of 5 Old 08-17-2012, 08:34 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
2006 JK Power Steering System Diagnosis
POWER STEERING SYSTEM
STEERING NOISE
There is some noise in all power steering systems. One of the most common is a hissing sound evident at a standstill/parking, or when the steering is at the end of it's travel. Hiss is a high frequency noise similar to that of a water tap being closed slowly. The noise is present in all valves that have a high velocity fluid passing through an orifice. There is no relationship between this noise and steering performance.
How to interpret the information below:
The condition is BOLDED. Then you have
#. possible cause followed by #. correction
OBJECTIONAL HISS OR WHISTLE
1. Steering intermediate shaft to dash panel seal. 1. Check and repair seal at dash panel.
2. Noisy valve in power steering gear. 2. Replace steering gear.
3. Inoperative or defective valve in pump 3. Replace pump
RATTLE OR CLUNK
1. Gear mounting bolts loose. 1. Tighten bolts to specification.
2. Loose or damaged suspension components. 2. Inspect and repair suspension.
3. Internal gear noise. 3. Replace steering gear.
4. Loose or damaged intermediate shaft or column. 4. Inspect and repair or replace.
MOAN
1. Pressure hose in contact with other components. 1. Reposition hose.
CHIRP OR SQUEAL
1. Loose belt. 1. Adjust or replace.
WHINE OR GROWL
1. Low fluid level. 1. Fill to proper level.
2. Pressure hose in contact with other components. 2. Reposition hose.
3. Internal pump noise. 3. Replace pump.
SUCKING AIR SOUND
1. Loose return line clamp. 1. Replace clamp.
2. O-ring missing or damaged on hose fitting. 2. Replace o-ring.
3. Low fluid level. 3. Fill to proper level.
4. Air leak between pump and reservoir. 4. Repair as necessary.
5. Reservoir cap not installed correctly. 5. Install reservoir cap correctly.
SCRUBBING OR KNOCKING
1. Wrong tire size. 1. Verify tire size.
2. Wrong gear. 2. Verify gear.
3. Tire Pressure 3. Adjust Tire Pressure
BINDING AND STICKING
DIFFICULT TO TURN WHEEL STICKS OR BINDS
2. Tire pressure. 2. Adjust tire pressure.
3. Steering components (ball joints/tie rod ends). 3 Inspect and repair as necessary.
4. Loose belt. 4. Adjust or replace.
5. Low pump pressure. 5. Pressure test and replace if necessary.
6. Column Intermediate shaft binding. 6. Replace Intermediate Shaft.
7. Steering gear worn. 7. Replace gear.
INSUFFICIENT ASST. OR POOR RETURN TO CENTER
HARD TURNING OR MOMENTARY INCREASE IN TURNING EFFORT
1. Tire pressure. 1. Adjust tire pressure.
2. Low fluid level. 2. Fill to proper level.
3. Loose belt. 3. Adjust or replace.
4. Low pump pressure. 4. Pressure test and repair as necessary.
5. Internal gear leak. 5. Replace gear.
STEERING WHEEL DOES NOT WANT TO RETURN TO CENTER POSITION
2. Wheel alignment. 2. Align front end.
3. Lack of lubrication. 3. Inspect and lubricate suspension compnents.
4. High friction in steering gear. 4. Replace gear.
LOOSE STEERING AND VEHICLE LEAD
EXCESSIVE PLAY IN STEERING WHEEL
1. Worn or loose suspension or steering components. 1. Inspect and repair as necessary.
2. Worn or loose wheel bearings. 2. Inspect and replace bearings.
3. Steering gear mounting. 3. Tighten / replace gear mounting bolts/ isolators to specification.
4. Gear out of adjustment. 4. Replace gear.
5. Worn or loose steering intermediate shaft. 5. Inspect and replace as necessary.
VEHICLE PULLS, DRIFTS OR LEADS TO ONE SIDE.
1. Tire Pressure. 1. Adjust tire pressure.
2. Radial tire lead. 2. Rotate tires.
3. Brakes dragging. 3. Repair as necessary.
4. Wheel alignment. 4. Align front end.
post #4 of 5 Old 08-17-2012, 08:50 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
removed - duplicate information
post #5 of 5 Old 08-18-2012, 08:31 AM
Clockworkorange
2006 KJ Liberty
I think the answer is in your own words. "until I back the wheel off slightly".
I was always told not to hold the wheel against the lock position because of the strain that you can here is happening under the hood. Stay backed off just enough untill you do not here that strain. What exactly the clicks are I do not know but if they happen at lock position then don't go there.
Clockworkorange is offline
Clicking noise from front left tire MoAllen KJ Liberty Forum 0 07-29-2012 05:28 AM
Whining/groaning noise when turning - power steering pump going bad? AVR2 KJ Liberty Forum 2 09-04-2010 07:31 AM
Power Steering Fluid Change or Power Steering Noise READ THIS 2003GCES KJ Liberty Forum 6 04-13-2010 03:27 AM
2002 jeep liberty power steering noise knuckleslammer KJ Liberty Forum 17 01-20-2010 10:36 AM
Small Noise in Steering Wheel When You Turn Elt31987 KJ Liberty Forum 5 09-23-2009 10:01 AM
