Please Help me Find Cooling Sys Leak - JeepForum.com
post #1 of 4 Old 09-24-2013, 09:49 AM Thread Starter
d5332
2002 KJ Liberty
Hi, our Liberty is not providing heat when its idling.
There is an apparent leak because I am having to add coolant to the reservoir every two days.
I checked everything I just cant find it.
Already ordered a new radiator and new thermostat but cant just simply changed them.
about 3 years ago the Liberty was serviced for a bad radiator and looks like the mechanic damaged the screws, new mechanic says he will not touch the screws unless I authorize the purchase of a $500 engine cover, new mechanic suspects threads are damaged, there is a thick putty type of stuff around a screw as if it was cemented in place.
I dont think the thermostat has gone bad due to the loss in coolant, there has to be a leak somewhere.
If I cannot visually identify the leak, what else can I do to identify the leak?
d5332 is offline
post #2 of 4 Old 09-24-2013, 01:35 PM
tommudd
2004 KJ Liberty
Check the water pump, they have a small weep hole on the bottom could be it or could be the radiator
Don't know what the tech is talking about a 500 dollar engine cover
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
tommudd is offline
post #3 of 4 Old 09-24-2013, 02:32 PM Thread Starter
d5332
2002 KJ Liberty
The engine cover the mechanic referred to was the aluminum / metal that the thermostat screws onto, like the timing belt cover, forget the name but its the actual metal piece that the thermostat screws on to.
I will have to check again tonight for wet parts, I will check the waterpump, underneath for the thersmostat and check the radiator again.
I just cant find puddles or trail of dry antifreeze anywhere.
d5332 is offline
post #4 of 4 Old 09-24-2013, 07:52 PM
streetglideok
2005 KJ Liberty
Timing chain cover. May be an overly paranoid mechanic. Buy, rent or borrow a coolant pressure tester, that will make the job of finding the leak a little easier.
streetglideok is offline
