please help!!!!! jeep wont start now - JeepForum.com
post #1 of 29 Old 10-17-2012, 09:42 AM Thread Starter
xxtegra
2002 KJ Liberty
i have a 2002 jeep liberty. it was sitting on car ramps for a week then when i went to drive it it was running on 5 cylinders .i thought was coil so i change that and still nothing . i changed all the spark plugs and it started to run on 4 cylinders. then it started working on 2 now it wont even start ! also did a compression test on one of the cylinders not working and showed fine.
the plug was wet so its getting fuel. any ideas what it is ? this been driving me nuts for a few days and i need it running asap!
xxtegra is offline
post #2 of 29 Old 10-20-2012, 08:30 AM Thread Starter
xxtegra
2002 KJ Liberty
anyone have any ideas besides badboyeatsdicks ?
xxtegra is offline
post #3 of 29 Old 10-20-2012, 05:38 PM
jstick911
Try swapping the coils to find a faulty coil, try swapping the injectors to find a faulty injector, or start by doing a compression test to all 6 cylinders. Hope this helps
jstick911 is offline
post #4 of 29 Old 10-20-2012, 06:02 PM
streetglideok
2005 KJ Liberty
I always like to start at the beginning. Why was the car on ramps to begin with?
streetglideok is offline
post #5 of 29 Old 10-21-2012, 08:22 AM Thread Starter
xxtegra
2002 KJ Liberty
i swapped the coils and it wasnt that. i didnt check the injectors but the plugs were wet so must be getting gas?.ill do a compression test on the rest of the cylinders. it was on the ramps cause i had the exhaust off to get welded
xxtegra is offline
post #6 of 29 Old 10-21-2012, 08:24 AM Thread Starter
xxtegra
2002 KJ Liberty
it seems like no power going to the coils
xxtegra is offline
post #7 of 29 Old 10-21-2012, 10:41 AM
streetglideok
2005 KJ Liberty
Check and see if you have power to the coils. With the key on, you should have 12v to one wire on each coil connector. The PCM controls the grounding of the coils to fire them. Now when you say it was running on 5 cylinders, then 4, then 2, then none at all, how did you arrive to that conclusion?
post #8 of 29 Old 10-21-2012, 11:12 AM Thread Starter
xxtegra
2002 KJ Liberty
ok ill go check now thanks
i had it running and none of the cylinders on the driverside work the exhaust was cold.
xxtegra is offline
post #9 of 29 Old 10-21-2012, 11:35 AM Thread Starter
xxtegra
2002 KJ Liberty
couldnt get any power even on the ones that run .maybe i did not do it correct.
first when it was on 5 cylinders i pulled the coil plugs one at a time till i found the missing cylinder. after i changed that one with a new one it didnt work still so i swapped it with one that did and then 2 were missing. im not really sure :S
xxtegra is offline
post #10 of 29 Old 10-21-2012, 11:45 AM Thread Starter
xxtegra
2002 KJ Liberty
its throwing codes for the coils thats not running too
xxtegra is offline
post #11 of 29 Old 10-21-2012, 01:44 PM
streetglideok
2005 KJ Liberty
If it didnt do it before you pulled your exhaust down, then you may want to go back and look for anything you may have damaged when you pulled the exhaust.
post #12 of 29 Old 10-21-2012, 02:03 PM Thread Starter
xxtegra
2002 KJ Liberty
i did there is nothing there . i can put my hand on the driverside bank nothing is firing how it runs on 2 cylinders is crazy !
i had power to the coil plugs with it running but not when just key on. wat is easiest way to check fuel ?
thanks for your help
xxtegra is offline
post #13 of 29 Old 10-21-2012, 02:06 PM Thread Starter
xxtegra
2002 KJ Liberty
i was thinking maybe water got in somewhere but i dont know where :S
xxtegra is offline
post #14 of 29 Old 10-21-2012, 02:25 PM Thread Starter
xxtegra
2002 KJ Liberty
or maybe the fuel is got dirt in it and clogged the injectors the only 2 that fire is on the driver side in the back.
xxtegra is offline
post #15 of 29 Old 10-21-2012, 03:29 PM
DeltaForceB85
2011 KK Liberty
Sounds like a strictly electrical problem. Tow it to someone with a code reader and see what codes are coming up.
-Josh
DeltaForceB85 is offline
