Part Time 4x4 Light On - JeepForum.com
post #1 of 9 Old 01-09-2007, 09:08 PM Thread Starter
CarolinaKJ
Hello fellow Jeepers,
This is my first post on your board. GREAT SITE! Came across it in a web search for jeep info/help. I have a question.
I have a 2003 Jeep Liberty Sport with the 3.7L, 4x4. It doesn't see any trail off-roading, but it does see seasonal (winter/snow) all wheel drive use. Over the holidays last month, I engaged the 4wd HI at about 15 mph while going up a hill as I have several times the previous 3 winters, and disengaged it back to 2wd HI going down the other side at about 15 mph. Nothing different than normal. However, this time, the PART TIME light remained on, although it is in 2wd HI. When I engage the 4wd HI, the PART TIME light goes off, and the 4wd is engaged.
The handle does not seem to be as far down as before when in the 2wd HI position, however I have driven close to 1k miles since this has begun.
I have tried shifting in to all positions trying to fix the problem, but with no luck.
All positions work fine, but I don't like seeing the PART TIME light on 24/7.
I bought the vehicle new in 9/03 will 11 miles on it, and it now has 98K miles on it, all most all of it highway. Other than a front right window lift motor, swith, and wiring going out, a left rear brake caliper freezing up, (both covered by Warranty) I have had no problems and do the maint. myself.
So my question is Is this common? What is the cause (electrical, mechanical, linkage, fluid ??? and how to fix it?
BTW, I have the 42RLE trans.
Thanks in advance for your response,
CarolinaKJ
CarolinaKJ is offline
post #2 of 9 Old 01-10-2007, 01:20 AM
Fouros
2004 KJ Liberty
it will be the transfer case position indicator switch , its situated at the top of your t/fer case the pin has probably become stuck
Fouros is offline
post #3 of 9 Old 02-15-2011, 10:18 AM
c2photog
2003 KJ Liberty
Not only is my part time light acting the same way but my speedometer is malfunctioning (always moving up and down) and my gas mileage has decreased to a miserable 11.5 mi / gallon--could these malfunctions influence such poor gas mileage?
c2photog is offline
post #4 of 9 Old 02-15-2011, 01:19 PM
01CHEEKEE
no, the switch is simply that...a switch...happened to us a day after we bought it...people drive around w/ them on if they don't care or want to pay to have it fixed...as for the gas mileage, that is really horrendous...check your math first, then maybe your plugs? they might be fouled up or out of gap...
01CHEEKEE is offline
post #5 of 9 Old 02-16-2011, 08:54 AM
c2photog
2003 KJ Liberty
My plugs were just replaced. New tires. Throttle body cleaning. And my math is verified by the on-board computer.I'm about to break down and go to the Jeep Dealer (whose service dept I do not really like). None of the recent services has helped my gas mileage. Another service dept suggested the engine may run "rich" d/t the speedometer malfunction....???? Any other suggestions?
c2photog is offline
post #6 of 9 Old 02-16-2011, 01:55 PM
01CHEEKEE
Fuel filter?
post #7 of 9 Old 02-16-2011, 09:25 PM
c2photog
2003 KJ Liberty
Good question on the fuel filter...I have no idea.
c2photog is offline
post #8 of 9 Old 02-17-2011, 08:52 AM
Cards81fan
Cards81fan's Avatar
2014 KL Cherokee
The fuel filter is not regularly serviceable in a gas model, I believe. Isn't it in/at the tank on the Liberty?
I've never gone looking for mine.
Of course, at 8 years old, it could well need serviced.
Mindset, skillset, toolset - in that order!
Cards81fan is offline
post #9 of 9 Old 02-21-2011, 07:57 PM
d5332
2002 KJ Liberty
Can out of gap plugs trigger the O2 sensors?
I replaced two sensors and they still occasionally come back on...I put platinum plugs which indicated that they did not need to be measured for gap.
d5332 is offline
Part time light is on in 2wd not in 4wd wes3312000 KJ Liberty Forum 7 03-24-2016 04:38 PM
Part time light on luke179 KJ Liberty Forum 5 09-06-2011 08:51 PM
part time light on when not in part time ytt1300 KJ Liberty Forum 10 01-23-2011 11:30 PM
I'm in 2WD but the part time light is on and I have no clue :) STSMWR KJ Liberty Forum 15 01-20-2009 10:52 PM
Part time light on all the time sharhack KJ Liberty Forum 2 07-31-2007 09:58 AM
