P1491 radiator fan relay control circuit - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > P1491 radiator fan relay control circuit
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRough Country Deals at JeepHut.comJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 06-26-2012, 11:58 AM   #1
cmagnacca
Troublecode for this popped up on diagnostic test on my 2003 liberty sport 3.7L. What is the best way to actually test the sensor, how long can I drive before it becomes a major issue?
Any help??
cmagnacca is offline   Reply With Quote
Unread 06-26-2012, 02:21 PM   #2
Millermagic
Check the fan relay.
2000 XJ - ProComp 3.5'' rear leaves, 3.5'' front coils, JK Shocks, TreadWright LT215/85r16 Crawler MT-E and some tow hooks. Skid plates in the garage.
Millermagic is offline   Reply With Quote
Unread 06-26-2012, 02:32 PM   #3
tjkj2002
2002 KJ Liberty
Any help??
It's a major issue right now.Pull the relay connector off of the relay and if it's a little melted replace the relay ASAP.
The fan relay is located about 10" under the battery,as shown in the pic below.
Only get the upgraded OEM replacement from the dealership as it has a larger heatsink to keep it cool.The pic above is the factory one which the aftermarket junk ones will look like.
tjkj2002 is offline   Reply With Quote
Unread 06-26-2012, 03:33 PM   #4
cmagnacca
Thanks
