P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage - JeepForum.com
post #1 of 6 Old 10-13-2008, 10:42 AM Thread Starter
jeepdaddy65
1972 CJ5
Does anyone know were the oil pressure sensor is located on a 3.7 L. on a 05 Liberty Rocky Mountain. I keep throwing this code and want to check the electrical connections. Thanks in advance for any help
jeepdaddy65 is offline
post #2 of 6 Old 10-13-2008, 11:35 AM
x99j
right above the oil filter. their is a wire connected to it.
06 kj 3.7l, 6speed manual, np241 command track
91 yj 2.5l, ax-5, np 231 3 inck lift, 31'' mud rovers
12 kk 3.7L, 42rle, mp1522, d-30, 8.25.
x99j is offline
post #3 of 6 Old 10-14-2008, 05:34 AM Thread Starter
jeepdaddy65
1972 CJ5
Thanks for the info. I'll check the connection and hopefully I won't throw that code again
post #4 of 6 Old 10-22-2008, 11:48 AM Thread Starter
jeepdaddy65
1972 CJ5
I checked all the connections and they are good. When I start it for the first time after it sits all night the oil light comes on and it throws the code again. When I start it up after the first time and everything is warm the oil light stays off. I hope my oil pump isn't going. But the code says it electrical. Any help or opinions on this would be great. Thanks
post #5 of 6 Old 12-16-2008, 05:52 AM
Canlibjeep
2005 KJ Liberty
Oil Pressure Light
I am experiencing the same problem. Was curious if you ever got it fixed. Was it the sensor?
Canlibjeep is offline
post #6 of 6 Old 12-16-2008, 08:24 AM Thread Starter
jeepdaddy65
1972 CJ5
I replaced the sensor and all is ok. I got the sensor at Autozone for around $19.00, After I replaced it I dissconnected the battery to reset the code, and it has been ok since.
P0158 02 circuit high voltage. mc55 KJ Liberty Forum 9 07-24-2015 01:13 AM
CRD oil pressure sensor light comes on andrewjake3 KJ Liberty Forum 37 10-08-2012 06:19 AM
Oil Pressure Sensor Help mt3 KJ Liberty Forum 6 12-15-2009 04:19 PM
p0161 O2 Sensor Heater Circuit (Bank 2 Sensor 2) DaniLaurette KJ Liberty Forum 1 01-19-2009 03:04 PM
Tire pressure sensor ruralroute01 KJ Liberty Forum 6 08-26-2007 02:19 AM
