P0500 - Speedometer Not Working - JeepForum.com
post #1 of 9 Old 07-24-2016, 07:46 AM Thread Starter
99WJ539918
This is on a friend's 2002 Liberty. Had this code three months ago. The wiring Resistance checked fine from the plug in the floorboard to the connector in the rear diff so I replaced the sensor with one from Advance Auto and zip tied the harness away from the parking brake cable so I wouldn't have the common issue of the wire wearing through. I cleared the code and it's been fine since. The wiring still checks out at 0 Ohms from the connector to the plug in the floorboard. Should these sensors be Mopar? Is there anything else I should check for? Should I replace both sensors (the one on the transmission)? Thanks, fellow Jeepers.
Build Thread
99WJ539918 is offline
post #2 of 9 Old 07-24-2016, 01:47 PM Thread Starter
99WJ539918
Any electrical diagrams available?
Build Thread
post #3 of 9 Old 07-25-2016, 03:31 AM Thread Starter
99WJ539918
Any help? Should I replace the diff and trans sensors with Mopar? Is there something else I should be looking for?
Build Thread
post #4 of 9 Old 07-25-2016, 12:26 PM
cranbiz
http://www.colorado4wheel.com/manual...2006-KJ-SM.pdf
This is the FSM for a 2006 but they have others. This is a full FSM with wiring diagrams.
cranbiz is offline
post #5 of 9 Old 07-25-2016, 01:08 PM Thread Starter
99WJ539918
The link didn't with for me. Thank you.
Build Thread
post #6 of 9 Old 07-25-2016, 01:15 PM
cranbiz
The board shortened the link. Try this one.
This opens up a download window and I just tested it.
cranbiz is offline
post #7 of 9 Old 07-25-2016, 02:52 PM Thread Starter
99WJ539918
It worked. Thanks.
Build Thread
post #8 of 9 Old 07-25-2016, 02:53 PM Thread Starter
99WJ539918
What had everyone's fix been? I've never seen a speed sensor fail in less than a year before, although this one is aftermarket. I'm thinking that I should just buy a Mopar sensor and try it.
Build Thread
post #9 of 9 Old 07-27-2016, 03:00 PM Thread Starter
99WJ539918
Anyone?
Build Thread
