P0038 Code? Need help Resolving.. - JeepForum.com
post #1 of 12 Old 09-28-2009, 07:34 AM Thread Starter
SilverGT
2004 KJ Liberty
Where is the O2 sensor fuse!? P0038 Code? Need help Resolving..
I just replaced the o2 sensor on my liberty the one that was throwing a P0137 Code..after installing the sensor i disconnected the battery for a reset of the check engine light. it went away for 20miles then came back but there is no codes to be pulled from the check engine light when i try the on/off/on/off/on method.
From what i have been reading it might be a resistor inside the ecu or a o2 sensor fuse...
Where is the o2 sensor fuse located? can anyone give me some insight.
SilverGT is offline
post #2 of 12 Old 09-28-2009, 10:58 PM
richd
2008 KK Liberty
You still have a problem with you O2 sensor curcuit.PO038=HO2S Heater Curcuit High Voltage Bank 1 Sensor 2.I would look for a broken or burnt wire.
richd is offline
post #3 of 12 Old 09-29-2009, 05:58 AM Thread Starter
SilverGT
2004 KJ Liberty
Yea rich. Its the weirdest thing. The check engine light was on, I used a scantron. Tired to pull the code, the scantron said PASS with no code but check engine light was still on.
So I erase the code, then 20miles later the check engine light came back on with still no code....I'm stumped.
SilverGT is offline
post #4 of 12 Old 09-29-2009, 01:28 PM
richd
2008 KK Liberty
That is strange,the computer should pick that up with the CEL on.You did have that PO038,so I would still double check the wiring.
richd is offline
post #5 of 12 Old 09-29-2009, 01:40 PM Thread Starter
SilverGT
2004 KJ Liberty
yea its the weirdest thing...i will check the wiring tonight but do you happen to know where the fuse is for this o2 sensor is? someone said there was a o2 sensor fuse somewhere.
upon further exam, i noticed the old o2 sensor had the wire zip tied to a brake line..looks like previous o2 sensor shorted itself on the exhaust at one point in its lifetime.
SilverGT is offline
post #6 of 12 Old 09-29-2009, 01:52 PM
richd
2008 KK Liberty
I have a 08KK,and my manual shows no fuse for O2s.I think you found your problem.Good Luck,and let us know.
richd is offline
post #7 of 12 Old 09-29-2009, 02:05 PM Thread Starter
SilverGT
2004 KJ Liberty
this was before I replaced that old 02 sensor with a new one. So I'm thinking the ecu is bad if there is no fuses for the o2 sensor.
When it shorted itself did it short out the ecu also?.
SilverGT is offline
post #8 of 12 Old 09-29-2009, 05:25 PM
richd
2008 KK Liberty
Not sure about ECU.I would find the problem,clear the computer,and see if the code comes back.
richd is offline
post #9 of 12 Old 09-30-2009, 06:37 AM Thread Starter
SilverGT
2004 KJ Liberty
I just got it scanned and the code P0420 came up. im assuming its the cat gone bad? should i put a non-fouler in and call it a done deal?
SilverGT is offline
post #10 of 12 Old 09-30-2009, 11:55 AM
richd
2008 KK Liberty
No.If you have a bad cat,its going to plug up your exhaust,and you wont have any power,second,you in NY and wont pass inspection.You cant have any code for inspection.
richd is offline
post #11 of 12 Old 09-30-2009, 12:03 PM Thread Starter
SilverGT
2004 KJ Liberty
its doesn seem to have power lost... and the p0137 code went away now it has the p0420 code. does it still mean the cat is no good? how can i check to see if the cat is plugged?
SilverGT is offline
post #12 of 12 Old 09-30-2009, 12:11 PM
richd
2008 KK Liberty
You can check them with a tempertaure sensor gun.Ive heard most muffler shops have a free check.The O2 sensor must have been bad for awhile.
richd is offline
OBD code p1281 ldang24 KJ Liberty Forum 11 12-07-2011 12:44 PM
please help got a code and noone can figure it out!!! jojobax KJ Liberty Forum 3 08-11-2009 05:43 AM
CRD code scanner help weantright KJ Liberty Forum 0 06-01-2007 11:25 AM
Help with a CODE BeachCrawler KJ Liberty Forum 1 12-29-2006 09:43 AM
Code 5.7 on CRD pierce1979 KJ Liberty Forum 5 10-26-2005 09:32 PM
