Oxygen Sensors? - JeepForum.com
post #1 of 13 Old 12-16-2011, 11:09 PM Thread Starter
403Lumberg
2003 KJ Liberty
Oxygen Sensors?
My Jeeps at 180 000km (111846 Miles) I was thinking about changing the oxygen sensors. What do you guys think, way over due? Change them all? or is there a specific one that will give the most bang for the buck?
I'm getting terrible fuel mileage, even for a Jeep! I get around 400km (248 Miles) to a tank, even if 100% highway. Easy on the peddle, 90% of the time, haha. Tires inflated on road, synthetic oil changes at 5000km or less, clean filter(K&N Cold air), no exta weight, new plugs last 6 months, new PCV valve. What else can I do, any ideas?
403Lumberg is offline
post #2 of 13 Old 12-17-2011, 06:41 AM
tjkj2002
2002 KJ Liberty
Your range sounds about normal for this time of year.If you had a O2 sensor issue your check engine light would be on but if you want to change them only get NTK or Denso O2 sensors,do not install bosch O2's.
tjkj2002 is offline
post #3 of 13 Old 12-17-2011, 03:42 PM
DaveJKJ
2005 KJ Liberty
Crappy winter gas and weather. Mine is worse too. If your 02 sensors were bad and causing problems you would be throwing 02 sensor codes and you have 4 of them. 2 before the cats and 2 after. I would leave them alone if no codes. The ones before the cats might affect gas mileage more I think if there is an open loop/closed loop problem and then it would be throwing sensor codes.
Lifted, Skids, Hooks, Rails, Trail Rash..
War Veterans Jeep Group #31
Black Jeep Society #217
DaveJKJ is offline
post #4 of 13 Old 12-18-2011, 10:46 AM Thread Starter
403Lumberg
2003 KJ Liberty
Thanks for the input/info guys. I guess I'll be waiting to replace them. At 180000km I'm doing alot of replacing, just trying to stay on top of things, maybe even get ahead! (if thats even possible) By this time next year I'll have a brand new Jeep built!! lol
post #5 of 13 Old 12-18-2011, 07:20 PM
tjkj2002
2002 KJ Liberty
Trust me it's never ending,besides the body(well most of it) I just have the stock engine and trans left but that will change soon enough.
tjkj2002 is offline
post #6 of 13 Old 12-19-2011, 08:53 AM
ifelovr
2002 KJ Liberty
I live in Jax Fl and with my 02' Lib I'm barely hitting the 200 mile mark for a FULL (up to the neck) tank of gas. I've changed about everything but the O2's only because I have'nt popped any codes. I've had just heard they can go bad but not to the point of sending a code. I'm playing it safe and just ordered them both from
car-stuff.com at a pretty good price.
ifelovr is offline
post #7 of 13 Old 12-19-2011, 05:43 PM
tjkj2002
2002 KJ Liberty
You have four O2 sensors,you'll need the other two also.Bad O2 sensors always throw a code,even lazy O2 sensors throws codes.Whatever you do do not put bosch O2 sensors in,your mpg's will really go down hill.You filling to the very top could be your main mpg problem.It's alright to slightly top off to the next dollar amount but you should never fill to the very top of the fill tube.This allows to much raw gas to enter into the EVAP system which does effect mpg's.Can take months to get all that raw gas out of the evap system,faster way is to replace the canister but that is big $$$.
tjkj2002 is offline
post #8 of 13 Old 12-27-2011, 07:22 AM
Lodator
I've had zero problem with my bosch sensors
Lodator is offline
post #9 of 13 Old 12-27-2011, 07:41 AM
streetglideok
2005 KJ Liberty
Or you saw zero change from old, worn out, contaminated sensors, to the new and poorly performing one size fits all bosch sensors, that a chinaman puts pigtails on to claim its direct fit? Question is, how much is the pcm compensating for those bosch sensors, that you will not feel without using a scan tool? How long before it cant compensate anymore, and starts throwing codes?
streetglideok is offline
post #10 of 13 Old 12-27-2011, 08:24 AM
Lodator
Can't answer that for you, but if I haven't seen any problems and my CEL went away I can't really complain. If I see problems the simple solution is to replace with NTK's right? So I'll just experiment with the Bosch's for now, I've run them narrow/wide band on my 2000 VW VR6T and had zero problems with them. Bosch is a good brand, just because it doesn't say MADE IN 'MURRIIICAAAAA on it doesn't mean a "chinaman" (not very politically correct now is it?) put them together.
I'll wait until the CEL comes back. Thank you for the input though?
Lodator is offline
post #11 of 13 Old 12-27-2011, 09:15 AM
tjkj2002
2002 KJ Liberty
Not saying bosch O2's are bad,they work great in other vehicles but not so great in Chryslers.They tend to not switch fast enough for Chrysler PCM's.It's a known fact by any tech that has been turning wrenchs for a few years.
tjkj2002 is offline
post #12 of 13 Old 12-27-2011, 10:15 AM
Lodator
Yea all around they are good sensors. Of course since I've used Bosch my whole life I went with them. If it comes down to the Jeep running a little crappier or different codes get thrown, then I'll switch them out. The Bosch's were the only thing readily available to me.
Lodator is offline
post #13 of 13 Old 12-27-2011, 06:56 PM
streetglideok
2005 KJ Liberty
Bosch used to be a benchmark standard, now, not so much. On certain vehicles, that they make the oe parts for, they are great. On other vehicles, their rendition of the part tends to be subpar. Just as tjkj said, they are notorious for slow switching on chryslers especially, but also on other vehicle makes as well. Ive also ran into the issue while working on VWs, that the bosch parts sold at the parts stores, are not the same level of quality as the bosch parts at the VW dealership, MAF sensors, and their air/fuel sensors come to mind.
Speed Sensors towerdude KJ Liberty Forum 3 02-11-2011 12:14 AM
Oxygen sensor 2004 Jeep Liberty barbara061 KJ Liberty Forum 1 05-13-2010 11:24 AM
Bad heated oxygen sensor blinkglory KJ Liberty Forum 1 03-12-2009 10:29 AM
Need some technical expertise..Sensors robbywatson7 KJ Liberty Forum 0 06-07-2007 05:27 PM
sensors flair1111 KJ Liberty Forum 1 04-13-2007 11:57 PM
