Overdrive button - JeepForum.com
post #1 of 26 Old 12-11-2004, 09:36 AM Thread Starter
Dupe
Overdrive button
Hi, I tried searching the overdrive subject I'm asking about but I couldnít find any specifics.
On short trips around town do you use the overdrive button on the side of the shifter? What are the advantages and disadvantages? How do I use it correctly? I havenít been using it...but, last night I pressed the button and the dash light showed overdrive "off" light? I'm guessing it is engaged unless you press the button and the overdrive light on dash shows off? How is gas mileage effected with it on?
2002 Liberty
Dupe is offline
post #2 of 26 Old 12-11-2004, 09:43 AM
Dunno
Hi Dupe
The Overdrive (O/D) button on the shifter is mainly for use when towing as it stops the tranny from over heating when driving over hilly roads. It basically stops the overdrive gear from engaging. You will also get worse MPG dis-engaging the O/D along with more engine noise at higher speeds because the tranny wont be able to shift into top gear. I hope this helps.
Dunno is offline
post #3 of 26 Old 12-11-2004, 10:04 AM Thread Starter
Dupe
So if I understand you correctly, I have been operating my liberty the right way.
Dupe is offline
post #4 of 26 Old 12-11-2004, 10:24 AM
Meister
i always wanted to know this, but i was too embarased to ask.
2005 Liberty Renagade 2WD
Meister is offline
post #5 of 26 Old 12-11-2004, 10:25 AM
festerw
festerw's Avatar
Really depends on the kind of driving, I turn the O/D off in my truck while driving around town because it likes to shift into overdrive at about 30 mph. I usually leave it off until I'll be going over 45 mph for quite a distance. I've actually got better gas mileage driving like this rather than with the O/D on.
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is offline
post #6 of 26 Old 12-11-2004, 11:23 AM
Dunno
Yeah good point Festerw
Jeep Liberty 2004 2.8 CRD Auto
Chevy Corvette 2001 5.7 Auto
Mini Cooper S 2004 1.6 Supercharged
Dunno is offline
post #7 of 26 Old 12-11-2004, 06:24 PM
hyedipin
hyedipin's Avatar
simply limits your jeep to 3rd gear.
bad choice on the highway unless you want to have +3000rpm on 50mph..
hyedipin is offline
post #8 of 26 Old 12-12-2004, 06:23 AM
valvestem
valvestem's Avatar
Here are the tranny gear ratios.
GEAR RATIOS The 45RFE gear ratios are:
1st . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.00:1
2nd . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.67:1
2nd Prime . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.50:1
3rd . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.00:1
4th . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.75:1<<Overdrive
Reverse . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .3.00:1
valvestem is offline
post #9 of 26 Old 12-12-2004, 05:59 PM
hyedipin
hyedipin's Avatar
Are there any Auto 5 Gear 4x4 SUVs that you know of?
hyedipin is offline
post #10 of 26 Old 12-12-2004, 06:39 PM
jay_bird
Yep, the CRD comes with a 5 Gear Auto (5-45RFE)
jay_bird is offline
post #11 of 26 Old 12-13-2004, 08:33 AM
hyedipin
hyedipin's Avatar
That's Nice..
CRDs need all the power they can get from wherever source it could be.
I better go check the CRD specs, I bet it beats the Escape Hybrid.
Any chance JEEP will make a hybrid? I doubt it
hyedipin is offline
post #12 of 26 Old 12-13-2004, 09:52 PM
LibertyV6
LibertyV6's Avatar
hybid
My main gripe w/ hybrids isnt the battery taking over for <25mph driving, it's the weak highway gas engines. Isnt is possible to put the hybrid batter in there to take over for stop and go BS driving-- and still have the 3.7 in there for get-up-and go driving? I realize that 28city/21highway probably looks strange, but hey, it's still an emission improvement right?
2004 Liberty 4x4. All Black Columbia Edition
Sunroof, 5 spoke Graphite wheels
ADDED MAGNAFLOW stainless muffler, Turbolator exhaust tip, K&N drop-in, ECLIPSE CD5000 8V HeadUnit, Infinity KAPPA speakers (all w/ Dynamat) run off RF 800a4 amp, One 12" KICKER Solo-Baric L7 subwoofer - run off RF 500a2 amp, 2 AURA under-seat bass shakers using alpine Flex2 amp, Front/ rear Mopar window flares, front slush mats, eurostyle antenna, Power Horn with Uniden PA Mic, 3" Smittybilt step rails
LibertyV6 is offline
post #13 of 26 Old 12-15-2004, 04:42 AM
Dunno
I have a 5 speed 2.8 CRD Auto but I don't know the specs or gear ratios, it seems to do 1800rpm at 60mph on the motorway/highway. Seems to do about 34mpg on the flat at that speed.
Dunno is offline
post #14 of 26 Old 12-15-2004, 07:46 AM
jay_bird
34MPG WOW!!!
I hope the version we get in the US has the same mileage. What do you get in the city?
jay_bird is offline
post #15 of 26 Old 12-15-2004, 08:52 AM
Dunno
It's no where as good as that around city driving but it's tough to get it under 21mpg average.
Dunno is offline
Window button illumination? JeepPower KJ Liberty Forum 15 01-28-2010 10:06 PM
Button does what? GolfGuy KJ Liberty Forum 7 03-28-2006 11:49 PM
Overdrive problem Coils Rule KJ Liberty Forum 8 02-04-2005 02:48 PM
Harsh downshift 3rd to 2nd or with button Ripster KJ Liberty Forum 1 05-10-2004 08:28 PM
Overdrive - On or Off StepheninLA KJ Liberty Forum 5 08-25-2002 09:07 PM
