Over-acceleration Liberty 2004, help needed! - JeepForum.com
post #1 of 5 Old 12-06-2011, 08:42 AM Thread Starter
martha
Hi,
After being away for a week I was driving my Jeep Liberty 2004 (automatic transmission) yesterday, and it was like driving a wild horse! While the engine normally goes low with a nice grumbling sound, this time i would not go below 1500 rpm in neutral and park, and completely over accelerated by itself in Drive. It is mostly uphill but I didn't even have to press the gas pedal for most of it. Needless to say, my brakes were completely overheated at the end of the ride. Its a 30 min ride each way, and it didn't get better at all.
Can anyone tell me what may have happened? I live in Haiti, so the mechanics are not excellent so it would be good to have an idea of what's going on before I take it anywhere...
Thanks a lot!!!
martha is offline
post #2 of 5 Old 12-06-2011, 08:44 AM
dmblair
Are you getting any codes? First thing that comes to mind is throttle position sensor for some reason!
dmblair is offline
post #3 of 5 Old 12-07-2011, 01:15 PM
cmclean
2003 KJ Liberty
Start with the simple things first, check that your floor mats/carpets are not holding the pedal down. After that I would check the cable and make sure that the throttle is closing properly.
cmclean is offline
post #4 of 5 Old 12-07-2011, 08:18 PM
LibertyTC
2004 KJ Liberty
Remove the throttle body air intake hose hose. Use throttle body cleaner and spray the throttle body & plate good and make sure that the linkage and plate are moving freely.
The throttle plate door should not be sticking and often a Q-tip with cleaner in it & around the inner edge top and bottom are required.
As you open and move the linkage the plate will move exposing edges. Once clean I use a bit of oil on edges.
The IAC (intake air control) controls the idle.
So with one T-20 torx bit screw on bottom of IAC remove it and do some spray cleaning in the port and also to the IAC.
It is probably so carboned up..it may be stuck good. You can also replace the IAC but cleaning normally does wonders.
Clean the Plunger & Areas
LibertyTC is offline
post #5 of 5 Old 01-06-2012, 12:00 AM
dlux
2011 KK Liberty
Wow, mine is disgusting. Thanks for the pics, huge help!!
What spray cleaner do you recommend? Dont wanna use the wrong one and jack it up. I've got enough problems already
2011 Liberty Limited 70th Anniversary Edition
dlux is offline
acceleration , gas , liberty , problems , transmission
2006 Liberty CRD stalls at abrupt hard acceleration ItBeMe KJ Liberty Forum 21 08-05-2012 07:37 PM
2004 Liberty 5-speed, Sluggish acceleration gab657 KJ Liberty Forum 3 07-27-2011 05:28 PM
Sluggish acceleration on 2004 Jeep Liberty shanahanjulie KJ Liberty Forum 10 04-07-2010 06:52 PM
Will a 2004 liberty bumper fit an 05 to 07 liberty metalhead KJ Liberty Forum 2 09-05-2009 06:39 PM
2008 liberty acceleration issues? mejeepgrl KJ Liberty Forum 1 05-28-2009 05:08 PM
