One brake light not working when lights on - JeepForum.com
post #1 of 12 Old 12-18-2010, 04:15 PM Thread Starter
d5332
2002 KJ Liberty
LinkBack Thread Tools Search this Thread Rate Thread
#1 (permalink) Today, 05:39 PM
d5332
New User Join Date: Oct 2010
Driver Break light not working with lights on
HI,
I was waved down last night by a nice passerby....
Turns out my left brake light is out so today I went to change the bulb...the bulb is fine...light works fine...huh....
Realized my left brake light is not working when the headlights are on. All 3 brakelights work IF the headlights are NOT on.
I am dumbfounded...
Can anyone help me?
What would cause one brake light to not work when you have your headlights on?
d5332 is offline
post #2 of 12 Old 12-19-2010, 01:23 AM
Billwill
2002 KJ Liberty
Most funnies regarding tail/brake lights are due to bad earthing within the tail-light cluster.If in doubt, try adding extra grounding to the bulbs, you can never have too much ground
The Sticky above, Liberty Service Manual has Section 8, Electrical diagrams. it is well worth well downloading this section as it covers all 2002/2003 models.
Billwill is offline
post #3 of 12 Old 12-21-2010, 01:09 PM Thread Starter
d5332
2002 KJ Liberty
I added a direct ground from the socket and that fixed the problem….
Did notice my wires are starting to rot…this is going to be fun…
Thank you very much for the information….greatly appreciate it….
d5332 is offline
post #4 of 12 Old 12-24-2010, 05:33 AM
Nilknarf
2004 KJ Liberty
Hi. I am experiencing the same issue, but with the passenger side break light. How do you add extra grounding to the bulbs? Thanks for your help.
Nilknarf is offline
post #5 of 12 Old 12-24-2010, 09:47 AM Thread Starter
d5332
2002 KJ Liberty
Your brake light socket should have 3 wires.....mine did...the black wire is the ground....
My black wire was not connected, probably bc the bulbs have a main ground but the main ground has gone bad....
I removed the tail light, I found a place to grind away a little bit of paint, drilled a hole, added wire from the black cable on the socket to the screw I placed in the hole I drilled and tightened it....
d5332 is offline
post #6 of 12 Old 12-25-2010, 02:44 AM
Nilknarf
2004 KJ Liberty
Thanks for your help. I'll give it a try.
Nilknarf is offline
post #7 of 12 Old 12-26-2010, 06:30 AM
waywardtravel
2006 KJ Liberty
D5332
I work in the electronics and electrical a lot. It's very interesting that it works with the lights off. I would take a multi-meter and check continuity to ground from the light. If it has two separate grounds, one from the three wires mentioned and one somehow case grounded check both separate while disconnected . Then try the same thing with the lights on. If the resistance (ohms) changes, you have an issue to chase down. If you add another ground with that issue your creating a short even if the light lights. This will effect something down the road. I would guess it's a relay issue but assuming ground is good to make the bulb not light at all and then adding a ground makes it light means both power and ground were power at that moment. No difference of potential and you already have a short). That would also say that the ground coming from the harness (assuming it's bonded to the light well) was power.
It might be easier to check for voltage.
Lights off engine on.
Check voltage from each pin or each of the three wires to chassis ground only one should have voltage with the brake pedal depressed
Lights on engine on.
Do the same, what changed?
If the wire harness was creating the short replace it don't add a better short path.
waywardtravel is offline
post #8 of 12 Old 12-27-2010, 12:52 AM
Billwill
2002 KJ Liberty
Hi waywardtravel, I totaly agree with you that the problem should ideally be traced down by means of a multimeter....if you know what you are doing! I was trained in Electrical Engineering light Current and have 34 years under my belt of working in Electronics in the mainframe Computer area. I have had to chase down about five wiring faults in my Jeep with the aid of a good wiring diagram.
If you are not an expert though...then I believe that trying a quick fix such as I recommended d5332 is well worth a try and should not cause any harm....the ground wire going to the bulbs is supposed to be "ground" so adding a shorter grounding path should never cause any harm...it may bring up a different problem altogether which may help in the final diagnosis. I do think though that the suspect ground wire going to the bulbs should be cut off at the bulb side and insulated while a completely seperate short ground is added to the bulb.
Wish I could tele-port myself to the States so that I could lend a hand
Billwill is offline
post #9 of 12 Old 12-27-2010, 05:37 AM
Nilknarf
2004 KJ Liberty
Thanks for the feedback, guys. Lots of information. What if I simply replace the entire tail light housing? Would that work?
Nilknarf is offline
post #10 of 12 Old 12-27-2010, 08:45 AM
Billwill
2002 KJ Liberty
I doubt it will make any difference but I may be wrong.
I have not removed my tail-light housings for a while, if the wires are long enough maybe you can swap over left and right units, leaving them dangling, to see if the "bug" moves with the housing itself!
Billwill is offline
post #11 of 12 Old 12-27-2010, 10:51 AM
waywardtravel
2006 KJ Liberty
Try the light swap if possible. I've never removed one yet.
BILLWILL The only "major" concern I have is that one mentioned the wire harness was rotting. If the light doesn't work only with the lights on and adding a ground makes it light, The odds are that ground is positive. It could very well be making contact with the 12v positive wire driving the light. Checking it will tell. Only voltage and ground on that ground wire. If it's disconnected and a new ground is run it would light but the power wire possibly making contact with the original ground is still sending power down that original ground path. This could cause many issues including fire. If it's not a broken ground issue and you happen to have night vision goggles it saves tons of time tracking a short. Not likley but it works amazingly well
Lighter note: I spent a year in electronics school for guided weapons long ago and they trained the nurses in the same location. Every time they saw us jump from even the tiniest shock OFF TO THE E.R. for an EKG. I swear all of us had patchy chest hair. That sucked
post #12 of 12 Old 12-02-2013, 07:46 PM
sbshealy
I know it's been a while since this thread was last updated, but I thought I'd add to it since this forum has given me so much back. This is on a 2000 Jeep Grand Cherokee WJ.
First of all - CHECK THE BRAKE LIGHTS BOTH WITH THE LIGHTS ON AND LIGHTS OFF.
A while back (maybe 6 months ago) I noticed a brake light out while backed into a parking spot at dinner (using the reflection on the building's window). Checked it the next day, and everything was fine. Checked it a couple days later, still good.
Fast forward to tonight. A car came up on me kinda quick, just enough for me to check my brakes in the garage (using the reflection on the garage door) right when I got in (lights still on). Sure enough the driver's brake light was out. Went inside and came back out. My wife hit the brakes so I could see which bulb was the brake light before I started unscrewing. Now it worked fine (now with the lights off). It took me a few minutes to figure out that the lights on/off trick is key to really checking things out. Looking real close the "lights off" brake light is a lot dimmer than the passenger's side (like it was the daytime brake). So now, I was sure the bulb was bad. Put a new one in that I had in my tool box. Same thing - so not the bulb. Removed the passenger light assembly and swapped driver/passenger assemblies around (same plugs so easy to do). The problem followed the driver's assembly (which is now attached to the passenger side) - so all the internal wiring is good. Switched the assemblies back around to normal, then switched all the bulbs around, and the problem stayed with the driver's assembly - so not a Jeep problem and nothing to do with bulbs. I pulled both assemblies back out, removed all the bulbs, and did basic continuity testing between the two. Everything matched up fine. So now what? Looked a little closer at the driver's brake light socket/recptical/housing/contact. I noticed that the brake light's "single contact" looked a little recessed - finally found the culprit. Looking closer, it was due to the plastic housing/ring failing. Basically the stress of the bulb/screw-in/contacts/etc has taken it's toll over the last 14 years. Imagine that! Anyway... I took a screwdriver and pried the contact/plastic up a bit. The contact finally released (either it was glued or just stuck real tight) so that the contact is now raised above the plastic a millimeter or so. So the contact now will physically mate with bulb's contact. Works fine now.
I'll have to keep an eye on it from here on out. The passenger's assembly looked like it was cracking too. The two lower bulbs (turn and reverse) looked better. These two only have contacts physically across from each other that may spread the stressing a little. The brake light has 3 contacts - 2 on one side and 1 on the other. That 1 by itself is where it is failing so maybe it is more stressed with 2 opposing it.
Hope this helps the next guy. Attached is a picture that says it all - it would have save my thousand words, right? This picture shows the recessed contact and failing plastic ring. I didn't take an "after" picture.
sbshealy is offline
Dashboard lights not working!!! mtmandersen KJ Liberty Forum 4 10-03-2011 11:16 AM
Drivers side front blinker light and rear taillight stopped working? osargd KJ Liberty Forum 2 08-28-2010 11:19 PM
Driver side tail lights, corner light and parking light out Lakee911 KJ Liberty Forum 1 06-20-2010 06:42 PM
ABS light on, handbrake light on, speedo not working scoobydazzaUK KJ Liberty Forum 10 01-21-2008 07:41 AM
trailer turn-signals and brake lights not working with Jeep Ducatista KJ Liberty Forum 3 06-12-2006 07:06 AM
