OME HD spring strut KJ lift - JeepForum.com
post #1 of 8 Old 02-29-2012, 07:50 PM Thread Starter
Destrobot
When I install the OME HD spring/strut/shock lift kit from jeepin by al, will 245/75/16 duratacs rub on the pinch weld or wheel well? If so, should i get smaller tires, spacer lift with the springs, wheel spacers or just hammer down the pinch weld?
Destrobot is offline
post #2 of 8 Old 02-29-2012, 08:44 PM
tommudd
2004 KJ Liberty
Hammer down the pinch weld if you have to
Easy to do, don't cut it off or anything like that just bend it over
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
tommudd is offline
post #3 of 8 Old 02-29-2012, 09:31 PM Thread Starter
Destrobot
alrighty, should i remove the plastic out and then hammer it down, then cut the plastic....or leave everything on, cut the plastic, hammer the pinch weld, then re-mend the plastic piece?
post #4 of 8 Old 02-29-2012, 09:35 PM
tommudd
2004 KJ Liberty
Heat gun
heat the plastic up some
cut it in a upside down "V" shape over the pinch weld
fold it up out of the way
3 lb hammer and bend the pinch weld over good
paint area so it doesn't rust
heat plastic back up and bend it back down over
smooth out over the flattened area
MUDD'S MOTORSPORTS
tommudd is offline
post #5 of 8 Old 02-29-2012, 09:42 PM Thread Starter
Destrobot
post #6 of 8 Old 02-29-2012, 09:46 PM Thread Starter
Destrobot
Originally Posted by tommudd View Post
Heat gun
awesome! soooo pumped to do all of this!
post #7 of 8 Old 03-01-2012, 08:26 AM
Oberon
2003 KJ Liberty
quick question, regarding HD springs. Will they hold up longer without sagging? Do they make for a harsher ride than the normal or light duty options?
Oberon is offline
post #8 of 8 Old 03-01-2012, 08:34 AM
tommudd
2004 KJ Liberty
My first lift with OME 927/948 Combo, I installed at about 20,000 miles replaced it at 120,000 and installed it on another KJ . It had sagged about 1/2-3/4 inch in that time so not bad at all.
As far as ride not harsh at all, firmer yes much more controlled than stock.
Out of over 20 installed no one has ever said it was harsh or rode to stiff or anything like that
Stock front springs are rated at 310 lb
OME 927s are rated at 400 lb
oh and I'm running OME 790s for CRDs rated at 500lbs
MUDD'S MOTORSPORTS
tommudd is offline
JBA Adjust-A-Strut MotherDearest KJ Liberty Forum 1 07-01-2011 11:07 AM
2002 Strut timcharlto KJ Liberty Forum 5 02-04-2011 04:28 PM
another strut question.. JTrenegade1 KJ Liberty Forum 2 08-20-2010 06:02 PM
Strut/Spacer Lift kits for KK DaveV KJ Liberty Forum 1 09-27-2009 01:02 PM
Upper Strut Spacers & Rear Spring Spacers meyerjim KJ Liberty Forum 0 05-07-2004 07:54 AM
