Oil Pressure Switch Question - JeepForum.com
post #1 of 4 Old 09-20-2007, 11:13 AM Thread Starter
modernist
Looking to replace the oil pressure switch on our 3.7. Never done this before and I'm curious to know, will oil start pouring out if I remove the old switch with oil still in the engine? Is there a torque setting once I get the new one in? Any info from those who've replaced theirs would be appreciated. Thanks.
modernist is offline
post #2 of 4 Old 09-21-2007, 03:47 AM
rob92xj
1992 XJ Cherokee
Do yourself a huge favor and get one from a local dealer as most of the ones I have seen from the local parts stores tend to leak badly.
Some oil will pour out of it when you unscrew it with or without oil in the oil pan since it is threaded into a oil passage in the block.
rob92xj is offline
post #3 of 4 Old 09-21-2007, 12:29 PM Thread Starter
modernist
Thank, I just picked up a new one at the dealer. Any thoughts on whether I should use teflon tape or just rely on the thread compound that already comes on the threading?
post #4 of 4 Old 09-21-2007, 01:12 PM
rob92xj
1992 XJ Cherokee
Just install it they are shipped with a sealer that will still allow it to ground properly.
rob92xj is offline
how to remove connector to oil pressure switch hawk1996 KJ Liberty Forum 11 01-21-2014 08:03 AM
oil pressure switch wiring yesirem KJ Liberty Forum 0 12-11-2009 02:59 PM
Question about Low pressure switch on 2002 f150 KJ Liberty Forum 1 08-13-2009 01:11 PM
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage jeepdaddy65 KJ Liberty Forum 5 12-16-2008 08:24 AM
Low Pressure switch gahendo KJ Liberty Forum 0 05-26-2008 06:56 PM
