Oil Pressure Sensor Help - JeepForum.com
post #1 of 7 Old 11-09-2009, 06:29 AM Thread Starter
mt3
i am having the problem with my 2002 liberty oil light coming on at stop lights. through the searching on this forum, it looks like the most likely culprit is the oil pressure sensor ....
can someone help me with some info?. ..... where is it located? is it hard to change it? how much is the part? .....
please let me know.
thanks!
mt3 is offline
post #2 of 7 Old 11-09-2009, 09:09 AM
yellocoyote
2002 KJ Liberty
Located just above the oil filter. Not difficult to change... took me 15 minutes or so, mostly because it's in an awkward location. Part itself is around $40.
yellocoyote is offline
post #3 of 7 Old 11-09-2009, 10:57 AM Thread Starter
mt3
it says remove oil pressure sensor .... is it screwed in? looks like a nut of some sort in the picture ....
do i have to drain the oil first?
mt3 is offline
post #4 of 7 Old 11-09-2009, 02:19 PM
nhcd538
Before you do all that, make sure your oil level is up to snuff. Not trying to insult your intelligence but it's worth checking if you haven't!
1999 TJ 2.5L AX5 NP231 D35/30 4.11's
*Disclaimer - I've probably had a few beers
nhcd538 is offline
post #5 of 7 Old 11-21-2009, 07:13 AM Thread Starter
mt3
thanks. that was the first thing i checked.i doubt that someone who wouldn't know to check the oil level first wouldn't even be on this forum looking for help.
mt3 is offline
post #6 of 7 Old 12-15-2009, 10:21 AM
crazyteenager
1995 XJ Cherokee
I logged in just to reply to this... There are more than enough people on here that are lost and crying because they dont know how to jump start their cars.... look at this response
Originally Posted by ceb0217;
I live with in an hour of the coast so getting sea foam is easy, but isnt the salt bad for the fuel system??? and how about the people that live farther away can you just foam up water and sea salt ??? if so what kind of mix do I use ??? 1table spoon to a gal of water??? and then how do I "foam it up" mabe a little soap????
"it became really noticeable, everyone I know says dont worry about it...But things dont just happen for a reason you know, I am very interested in seeing what you come up with."
crazyteenager is offline
post #7 of 7 Old 12-15-2009, 04:19 PM
GearGuy10
You'd be surprised. There's a thread on the XJ forum from a guy in Oregon who changed his radiator fluid and replaced it with straight water. It then froze solid with the recent weather and he wanted to know how to thaw his engine out. He then proceeded to ask what temperature water froze at. I'd like to think these threads are pranks, but the longer I live and the more people I meet the more I begin to think there's a whole segment of society that don't have a clue.
Anyway...disconnect the wire from the end of the sensor and use a wrench on the silver nut looking part of it to remove it. An open end wrench works best. It will take a while to get it out, and the new one in, because of the tight space. Lots of wrenching. But it is easy enough.
HIS: 1998 Cherokee Sport Chili Pepper Red-SOLD
DrawTite front hitch
HERS: 2009 Liberty Sport Light Graystone Pearl
100% Stock
GearGuy10 is offline
CRD oil pressure sensor light comes on andrewjake3 KJ Liberty Forum 37 10-08-2012 06:19 AM
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage jeepdaddy65 KJ Liberty Forum 5 12-16-2008 08:24 AM
TMPS Tire Pressure Sensor Replacement Question snowboardny KJ Liberty Forum 2 09-07-2008 08:07 AM
Tire pressure sensor ruralroute01 KJ Liberty Forum 6 08-26-2007 02:19 AM
Faulty Tire Pressure sensor? Blue79 KJ Liberty Forum 1 08-02-2005 05:32 AM
