Oil light on after engine swap. Help! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > Oil light on after engine swap. Help!
8.8 Swap Kit w/ TRUSS for JeepsROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 02-13-2015, 12:49 PM   #1
dcowans
Check oil light is on after doing an engine swap from an 02 to 03 Liberty 3.7 auto fluids are all fine. Please help!!
dcowans is offline   Reply With Quote Quick reply to this message
Unread 02-13-2015, 02:49 PM   #2
Tombo_ontario
2002 KJ Liberty
I'd check the oil pressure sensor (sending unit) just above the oil filter...
Tombo_ontario is offline   Reply With Quote Quick reply to this message
Unread 02-13-2015, 08:59 PM   #3
kjsteve
2002 KJ Liberty
They seem to be a common issue
KJ-mostly stock for now
Fr. Mopar recovery hooks and rear Curt receiver tow hook
Discoverer A/T3
kjsteve is online now   Reply With Quote Quick reply to this message
Unread 02-14-2015, 08:51 AM   #4
dcowans
Yikes hopefully it doesn't have low oil pressure. That sensor was the only connecter I had to swap from the other harness I noticed that the 03 has one wire and the 02 has 3. Thanks for the help all let you know if replacing the sensor works
Unread 02-20-2015, 07:10 PM   #5
olliehopnoodle
1982 FSJ Cherokee
You'd know it if you don't have oil pressure at all.
Your swap sensor swap/wire swap probably isn't correct.
That's really weird, I thought they would have been the same. No one ever mentioned it before. I looked it up on autozone and they show the same part number.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline   Reply With Quote Quick reply to this message
Unread 02-22-2015, 06:45 PM   #6
NoahHazin
try putting a manual gauge and see what the oil pressure is, if it is high then you know its the sender or sensor, if not....your screwed
NoahHazin is offline   Reply With Quote Quick reply to this message
