Oil filter on 2004 Liberty - Page 3 - JeepForum.com
post #31 of 36 Old 09-03-2006, 10:04 PM Thread Starter
gcotterl
2004 KJ Liberty
Oil Filter
Removing the oil-drain plug is NOT the problem.
The air filter is NOT the problem.
It's the oil filter that's hard to remove.
gcotterl is offline
post #32 of 36 Old 09-04-2006, 08:39 AM
jeepjeepster
If you have a tranny skid, it can be kinda tricky to get the plug off.
jeepjeepster is offline
post #33 of 36 Old 09-04-2006, 09:29 AM Thread Starter
gcotterl
2004 KJ Liberty
Oil Filter
The oil-drain plug is NOT the problem.
The oil filter is hard to remove.
gcotterl is offline
post #34 of 36 Old 09-04-2006, 10:39 AM
jeepjeepster
I had to.
post #35 of 36 Old 09-04-2006, 11:24 AM
dcxman
2006 KJ Liberty
Personally, I'd blast!
dcxman is offline
post #36 of 36 Old 09-04-2006, 03:51 PM
Intrepidjeep
Intrepidjeep's Avatar
Whenever you do get the filter off, you might try using the larger oil filter that Chrysler used to specify for the big V8's.
I believe the current filter is the "shorty" style PH16 (Fram number) and the larger filter is PH8.
The larger filter just has about a 2" deeper body, so that it's much easier to grab onto with your hands or the wrench. It also holds a bit more oil, so your oil changes will take a bit more oil to fill the crankcase properly as a result.
Another benefit of the larger filter is that it has a larger filter element inside for educed restriction and more pressure to the bearings.
-- Marcus
Cape Canaveral, Florida
2005 Jeep Grand Cherokee Laredo 4.7L
2005 Dodge Durango SLT 4.7L
Intrepidjeep is offline
May buy 2004 Liberty 3.7 4WD 5spd USDIG KJ Liberty Forum 13 11-27-2009 03:15 PM
Will a 2004 liberty bumper fit an 05 to 07 liberty metalhead KJ Liberty Forum 2 09-05-2009 06:39 PM
How do you remove the IAC in a 2004 Liberty jakewire KJ Liberty Forum 1 10-03-2008 08:30 PM
2004 Liberty Problem GaryKJ KJ Liberty Forum 1 11-25-2007 11:04 AM
2004 4X4 Liberty omegamotors KJ Liberty Forum 1 09-07-2004 08:34 AM
