Oil dripping on the exhaust causing a nasty smell. - JeepForum.com
post #1 of 4 Old 04-22-2013, 05:16 PM Thread Starter
robodiaz
So a while ago I was smelling fumes in the cabin. At certain angles I could see smoke sometimes on the passenger side.
I looked at the fuel lines and hoses and couldn't find anything. I did notice a small oil drip on the ground and noticed oil marks around the exhaust especially where the catalytic converter connects. Here's a pic.
I've tried to feel around up there but I can't feel any holes or anything. I'm not very knowledgable about cars other then I can follow instructions pretty well. But what should be my next step to find where the oil is leaking from?
I also noticed alot of oil near the electrical plugs on the cat.
Any help or speculations are really really appreciated. Thanks!
robodiaz is offline
post #2 of 4 Old 04-22-2013, 06:07 PM
TwoBobsKJ
2003 KJ Liberty
The valve cover gaskets are leaking - a common issue with the 3.7L engine with the stamped steel valve covers. The leak is typically at the lower, rearmost bolt location - which is right above the cats.
The gasket replacement isn't technically but does require a decent assortment of tools and some mechanical experience. I got a quote from my local dealer for the passenger side (the more difficult side) just for giggles and they wanted $220! An independent shop I'm sure would charge less.
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, ARB Bull Bar, Smittybilt XRC 9500lb Winch, 4X Guard Trans skid, Skid Row Engine skid, Factory T-case & Tank skids, Custom BoulderBars, JBA Front Coilovers, OME 948 rear springs, Bilstein rear shocks, JBA A-Arms, Moabs with Goodyear Duratracs 265/70-16
TwoBobsKJ is offline
post #3 of 4 Old 04-22-2013, 06:28 PM Thread Starter
robodiaz
Awesome. Thanks Bob for the info!
robodiaz is offline
post #4 of 4 Old 04-23-2013, 11:56 AM Thread Starter
robodiaz
The first quote I got from a dealership was a little over $300. I'm going to call a couple of other local/trusted shops and see what they say but I might try it out myself.
I was reading this writeup on changing the valve cover gaskets.
http://www.jeepkj.com/forum/f196/pas...-gasket-47815/
robodiaz is offline
fumes , oil leak
