Oil Changes - The unwritten step? - JeepForum.com
post #1 of 3 Old 03-18-2012, 09:33 AM Thread Starter
missioncontrol
2002 KJ Liberty
Hi guys, I've been searching like mad through google to get a definitive answer, but ended up with more questions...
Here goes:
Basically I've had my '02 Liberty since May 21, 2011. I've changed the oil every 4k miles (though they recommended 5k). Well after my last oil/filter change I would occasionally have the engine lamp ding and stay lit for a few seconds then go out. Oil levels were fine, so I wrote it off as a possible sensor issue since it didn't stay on nor did I hear any knocking while the light illuminated. Well Friday I swung by my mechanics to get a second opinion on another minor issue I was having. I mentioned the oil lamp issue, he asked if I performed a reset after the most recent oil change.
I said, "no as I thought I needed an OBD tester to clear codes." (My old Bronco needed one)
He said that I didn't need one and it could be done from the dash. He turned the key to "ON" then held down the trip odometer and all the gauges cycled through. He said i should do with with every oil change.
Well when I got home I thought I'd learn a little more about this, but everything I've seen on the net says I should turn the key to "ON" had hit the gas pedal 3 times within 10 seconds. So with that I'm a little more confused as to what the trip odometer button cleared.
So basically is there a un-written step for clearing codes now with oil changes?
missioncontrol is offline
post #2 of 3 Old 03-19-2012, 04:41 AM
Billwill
2002 KJ Liberty
Here goes:
Your mechanic should move into Sales....his talents are wasted where he is at the moment.
The trick of holding down the Odo meter trip button while switching on the ignition is merely to test that all the lamps illuminate and that the gauges are functional.......nothing more than that.
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
post #3 of 3 Old 03-19-2012, 06:50 AM
streetglideok
2005 KJ Liberty
Lol pretty much yep. All that does, is do a self test of the instrument cluster, and on some chryslers at least, will display what software version the cluster is running. Apparently your mechanic is just that, a mechanic. Go seek an auto technician, as there is a difference. Mechanic=old days of throwing parts at a vehicle till its fixed. Technician=like a doctor on a vehicle, but we dont do trial and error like doctors do,lol.
Your engine light is supposed to come on when you turn the key on, and first start the vehicle, as a self test, then it should turn off. If it stays on, then there is a problem. Oil changes are not directly related to the engine light.
Now some vehicles, particularly GMs, but many others as well, have oil life monitors, and require reset after an oil change, and they are not tied to the engine light in any way.
streetglideok is offline
Step-by-step 3.7 Water Pump Replacement Videos TinkerJohn KJ Liberty Forum 15 07-18-2014 08:34 PM
Step by step list to replace an automatic transmission and converter handymanextra KJ Liberty Forum 1 02-24-2012 10:51 AM
Step-by-step 3.7 Water Pump Replacement Videos Elt31987 KJ Liberty Forum 1 09-21-2010 05:05 AM
Smittybilt step rails? minilowz KJ Liberty Forum 0 02-21-2005 11:27 AM
STEP BARS ASHEE BABE KJ Liberty Forum 0 07-05-2002 03:42 PM
