Quantcast Oil change - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > Oil change
Official Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFGWant a weekly chance to win $50 in Jcr bucks?
Old 02-07-2008, 03:24 PM   #1
847jeff
1983 J-Series Truck
Oil change
I've changed my own oil on the Lib the last 3 times. The thing is that its THE WORST vehicle I've ever serviced. Am I doing something wrong and missing an easier way of getting to the filter? My arm's starting to rebel.
'03 Liberty Renegade, 240/70x16 Cooper Discoverer ATR,K&N replacement filter
'83 J-10 AMC 360 V-8,Edelbrock intake and 4 bbl, Summit 8600 cam, 727 Auto,Flowmaster 50 Delta, TFI,K&N filter, long bed, D44 front, AMC 20 rear, 33x12.5r15 Treadwrights on Minty's 15x10.
847jeff is offline   Reply With Quote
Old 02-07-2008, 03:36 PM   #2
Jakked
I don't know if you have a different radiator shroud or what, but I'm able to take off the filter with one arm (reaching in from the top), then snake it past the belts while keeping it right side up.
My arms aren't particularly small, but it definitely helps to have a "wrench off" nut on the end of the filter.
I'm actually pretty happy with the libby--one of the few vehicles I've owned that there's enough ground clearance that I don't have to jack it up (and put it on stands) before getting underneath it.
2004 Liberty Sport 3.7L A/T 4x4 Cmd-Trc
Former 4x4s:
1999 TJ 4.0L I-6 4x4 5-Sp *Mods*
1986 Trooper 2.3L I-4 4x4 5-sp
Jakked is offline   Reply With Quote
Old 02-07-2008, 03:39 PM   #3
847jeff
1983 J-Series Truck
I put mine on stands and reach through the skid plate, steering linkage and the bumper. I use a 3/8 ratchet w/ an extention, universal, and filter adapter.
Old 02-07-2008, 04:13 PM   #4
Jakked
Have you tried going through the top?
I use a K&N filter, and the only tool I need is a medium adjustable wrench set for 1".
Former 4x4s:
Old 02-07-2008, 04:53 PM   #5
indianrefining
If you've got the tow package and extra cooler, you can't get to it from above. You've got to snake your arm up from below. And I agree - it's a pain in the arse (as well as the arm)!
indianrefining is offline   Reply With Quote
Old 02-07-2008, 08:29 PM   #6
847jeff
1983 J-Series Truck
Mine came with the towing receiver. Oh my lucky arm!
Old 02-07-2008, 10:27 PM   #7
jeepjeepster
Yup, if youve got the bigger shroud then the oil change just sucks.
Try changing the oil in a Hemi WK if you really want to have fun.
jeepjeepster is offline   Reply With Quote
Old 02-08-2008, 04:05 PM   #8
LibertyLimited
Best way to fix that problem it go to a Jiffy Lube type of place and have them do you oil change for you.
[B]Let us never negotiate out of fear. But let us never fear to negotiate.[/B]
[I][B]- John F. Kennedy[/B][/I]
LibertyLimited is offline   Reply With Quote
Old 02-08-2008, 08:17 PM   #9
847jeff
1983 J-Series Truck
I use Mobile 1 oil and filter, an oil change with that at a garage costs $76. I'll stick to skinning up my arm.
Old 11-08-2009, 09:20 AM   #10
Slithering_Joe
Maybe there's a shroud difference but our gasoline '05 Libby is a breeze to change the oil. Oil filter drops in easily through the top.
4.0L TJ 5.7L CTS 3.7L KJ
Slithering_Joe is online now   Reply With Quote
Old 11-08-2009, 12:45 PM   #11
liquidxit2
I do mine in 15min without having to jack it up. The key is reaching in the front drivers side well. I kinda stretch the front fascia/plastic bumper a little, but a tight filter still gets me. Just make sure before you snug it on put a coat of oil on the o-ring. Since the first change I did I havent had an issue getting them off.
SOLD Ol' Blue: 2006 Jeep Liberty Renegade 4x4 Lifted and loud.
Fran: 2002 Jeep Grand Cherokee Limited 4.7 low output, quadra drive. Kolak 3in cat back flowmaster SUV 50, magnaflow 3in cat, airaid JR kit, modded airbox with ram air, P.I.E. aux adapter, surco 45x50 rack, front/rear/cargo husky liners.
liquidxit2 is offline   Reply With Quote
Old 11-08-2009, 05:15 PM   #12
RageOfFury
2011 WK
I did my first DIY oil change today. Since I don't have the tow package, thus no huge electric fan, I was able to get the filter off quite easily using just my hand.
I had a lot of fun today I gotta say. Changing oil on the KJ is easy! I used German Castrol and a Fram Extended Guard filter.
RageOfFury is online now   Reply With Quote
Old 11-09-2009, 03:21 PM   #13
nhcd538
2002 KJ Liberty
Funny this comes up, I just did my oil the other day and was cursing the damn thing out. It's easy to remove the old filter, the trick is getting the new one threaded. You need go-go gadget arms!
Seems like more of a b**ch every time I change the oil.
2004 WJ Laredo 4.0L 42RE NV242
nhcd538 is offline   Reply With Quote
Old 11-09-2009, 03:32 PM   #14
Steven73
It's really not that difficult
I changed my oil and filter on Saturday, and I've been changing my own oil and filter on this 2003 Jeep Liberty since I bought it new in 2002. Honestly, it is really easy. I use a regular oil filter metal strap wrench to get the thing loose and then I take it off by hand from the top, bringing it down upright through the drive belt, making sure not to spill oil on the belt of course. I lift the oil filled filter up and over the radiator shroud. Then use a lint free rag to wipe the metal oil filter housing on the engine block to remove any dirt etc. You can get a good feel of how the new filter should be angled on when you do this. Run the clean rag around the smooth metal housing for the oil filter ring, memorize how it feels, then put some clean oil on the new filter rubber ring and angle the position of the filter a little more than you think you should, and it should spin right on. Major point is to make sure you don't spill any oil on the drive belt, and when taking off the old filter plan on the dirty oil from the filter draining pretty far to the left of where the oil filter is located. There's a weird drain channel that takes it on this course. I've had a couple of nice dirty oil spills because I forgot to place the drain pan to the left of the filter location.
I like the Fram PH 3600 spin on filter because you can get a good grip on the rough outer end to fit it tight to the block without using a filter wrench to finish the job.
Steven73 is offline   Reply With Quote
Old 11-09-2009, 04:06 PM   #15
nhcd538
2002 KJ Liberty
I'm not saying it's difficult and I've changed the oil on this pig a hundred times. What I was saying was this last time, for whatever reason, I had a hell of a time getting the filter to thread on. I must have been overtired or something.
Glock Forum
