#1 | |
oil change
New Liberty 03 with 1500 miles on it was going to do a oil change, any tipes on getting to the oil filter.... not very user friendly
#2 | |
Oil Change
If you have the towing package like my wifes 2002 Lib. you can only reach the oil filter from the bottom.The factory oil filter is very tight! I had to wrap a piece of sandpaper around the inner rim of the strap wrench to keep it from slipping! You can take off the front skid plate which gives you a little more clearance but I usually leave It on [to lazy to remove] and reach up, scraping the sides of my arms and remove the filter.Put drain pan under opening in the skid plate as there is a funnel built in to direct it to the hole. On my 03 Fredom edition [no towing package] there is enough clearance to reach the filter from the top [much easier] I have since been using the Fram filter with the the no slip grip [much easier to remove] Don`t worry the next time is a lot easier.Good luck!
[COLOR=darkred]DAN O3 RED FREEDOM EDITION XOXO AIR INTAKE AIRAIDE THROTTLE BODY SPACER COBRA 75WXST CB ALL SKID PLATES & MOPAR DUAL OUTLET EXHAUST ALSO PATRIOT BLUE 02 LIBERTY LIMITED ALL OPTIONS EXCEPT SUNROOF[/COLOR] |
#3 |
Thanks will give it a try tonite. What type of gas mileage are you getting ? any mods to improve
#4 | |
Modifications
[COLOR=darkred]DAN O3 RED FREEDOM EDITION XOXO AIR INTAKE AIRAIDE THROTTLE BODY SPACER COBRA 75WXST CB ALL SKID PLATES & MOPAR DUAL OUTLET EXHAUST ALSO PATRIOT BLUE 02 LIBERTY LIMITED ALL OPTIONS EXCEPT SUNROOF[/COLOR] Last edited by DAN C; 09-01-2003 at 06:41 PM.. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
