noisy fan - JeepForum.com
post #1 of 4 Old 08-01-2007, 04:48 PM Thread Starter
skykris
2006 KJ Liberty
noisy fan
need advice
i have 2006 jeep cheerokie 2,8crd - 20 000km
and i had few issues already on it (leaking oil from tubrine and transmision)
and now I have another one
Nosiy fan (squeeking) on radiator , and seems to be loose a little bit
skykris is offline
post #2 of 4 Old 08-01-2007, 05:05 PM
merlinTec
merlinTec's Avatar
Hi
Not a known issue when does it squeak? Are you sure it’s the fan? Have had the alternator pulley do this as there is a one way clutch in the pulley. Have also had belt issues but on earlier models. If it’s a manual have also had dual mass flywheels make a squeak on shut down and at star up.
Regards,
Simon
merlinTec is offline
post #3 of 4 Old 08-02-2007, 05:18 PM Thread Starter
skykris
2006 KJ Liberty
I powered down engine and moved fan by hand
I ve been in jeep dealer in dublin - they said it is a bearing on fan motor , will repair next week
kris
skykris is offline
post #4 of 4 Old 10-03-2014, 07:13 PM
andrewjake3
2005 KJ Liberty
I have an answer for that squeaking of the pulleys.
I paid to have the tensioner pulley changed and I still had squeaking.
So I got my squeeze bottle of high speed electrical motor lubricant caster oil with the pullout tube.
I bit on the end of the tube until i got it bend at a 90 degree angle.
Turned the bottle upside down, jockeyed it down in between the belt and cowling to the pulleys, squeezed and lubricated both side of the bearings on both idler pulleys and the tensioner pulley, then inside the tensioner pulley where the spring is located and ((voila)) no more damn squeaking.
They were all squeaking and bearings tight as new.
SWEET!
Now, I have a question?!?
It idles at 750 rpm, like it should, but it shakes (like it should) at that idle speed but when I push the throttle up to say 900 rpm it smoothes out so pretty.
How can I ease the idle up 150 rpm?
It's not like the old days when I open the hood and there is an idle screw on the carburator.
andrewjake3 is offline
2003 Liberty A/C noisy - clutch or...? subkron KJ Liberty Forum 1 04-30-2009 09:55 AM
Noisy suspension??? joelfred31 KJ Liberty Forum 5 12-17-2008 07:18 PM
'08 liberty noisy 4-HI jebus_jeep KJ Liberty Forum 0 09-15-2008 07:38 PM
How to oil noisy door? dac122 KJ Liberty Forum 1 04-02-2007 04:07 PM
Noisy 5-speed Art H KJ Liberty Forum 7 03-06-2004 05:57 PM
