Noise from steering.. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > Noise from steering..
*VOTE NOW Help Metalcloak Giveaway an XJ Suspension*Stainless Steel Door Hinge PinsPoly Door Hinge Bushings
Unread 05-11-2014, 02:24 PM   #1
romz65
Please give me some idea as to what might be the problem. I hear noise like coming from steering or when turning in corners but not exactly know what it is. It's sort of something dry that needs oiling or something.. Thanks for any support.
romz65 is offline   Reply With Quote
Unread 05-11-2014, 03:25 PM   #2
02blue
2002 KJ Liberty
Power steering unit may need fluid or a change of fluid if dirty. Not sure what year you have but if its red its ATF+4 if amber it's Mopar Power steering fluid. Early KJs used PS fluid. Later use ATF+4. They shouldn't be mixed.
"Hey, ya never know til you try." Kurt Russell-Big Trouble in Little China
02blue is offline   Reply With Quote
Unread 05-11-2014, 03:31 PM   #3
romz65
Thanks a lot. It is a 2002 model KJ auto.
Unread 05-12-2014, 11:05 AM   #4
gombie72
I had this problem too with the same jeep. Im not sure which fluid I used but you need to fix that right away. I didnt and it led to me having to replace it 3 times. NOT FUN
gombie72 is offline   Reply With Quote
Unread 05-12-2014, 11:18 AM   #5
romz65
Please clarify when you said 'replace it 3 times'. Thanks
Unread Today, 09:02 AM   #6
gombie72
i really only had to replace it twice, but it was 3 different pumps that were used. The first pump just went bad over time. And I waited until it literally came apart to replace it. It tore up the hose a bit but i didnt really notice. When i put the 2nd pump in, the hose failed on me and destroyed the pump again. I put in a 3rd pump and now its working fine
Unread Today, 09:08 AM   #7
ZJ9593Jeep0588
When I take sharp turns at slow speed. say in a parking lot. I hear a popping and or clicking noise coming from the front end. I replaced all front wheel bearings and the diff is fine. Ball joints are all good. Linkage is tight on everything. Only thing is my shocks and coils are really old. Are you problems similar
ZJ9593Jeep0588 is offline   Reply With Quote
Unread Today, 09:20 AM   #8
02jeepliberty
I too have this problem, when it clicks and clunks, can you actually feel it in the steering wheel? I also have a 2002 KJ auto...
02jeepliberty is offline   Reply With Quote
Unread Today, 10:09 AM   #9
02blue
2002 KJ Liberty
Tie rod ends? Are you sure your ball joints are good? Might try this.
http://www.jeepkj.com/forum/f202/how...-joints-27868/
