Noise from around the rear right wheel - JeepForum.com
post #1 of 6 Old 10-10-2009, 10:14 PM Thread Starter
Sinphar
2002 KJ Liberty
Hi all,
I recently found a strange noise (sounds like something being rubbed) from around the rear right wheel of my 2002 liberty when it decelerated to a complete stop. This sound started to be heard after an automated car wash, which included a wheel cleaning. Does anyone know what was broken? Thank you for answering in advance! (The tire size is 235/70/16.)
Sinphar is offline
post #2 of 6 Old 10-11-2009, 12:01 PM
LibertyTC
2004 KJ Liberty
02's have drum brakes on the rear I believe. How many miles on your vehicle? Does this sound only come with a brake application or sound happens without braking?
With drum brakes, you could have got some water/rust in there, and you can try to to lightly apply emergency brake while moving forward to remove rust.
Otherwise inspection for rear brakes & spring /bearings is in order.
LibertyTC is offline
post #3 of 6 Old 10-11-2009, 07:11 PM Thread Starter
Sinphar
2002 KJ Liberty
Thank you for the suggestion.
Yes, it has drum brakes on the rear and has run 62,000 miles.
The sound only happened when the brakes were applied.
I'll try what you suggested. Hope it's only a minor rust problem.
Sinphar is offline
post #4 of 6 Old 10-11-2009, 10:41 PM
T-birdJunkie
2002 KJ Liberty
Probably due for brakes. It's at 62,000 miles, ya know.
T-birdJunkie is offline
post #5 of 6 Old 10-12-2009, 04:24 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Perhaps some water/soap got inside the drum or knocked some rust off. If the noise does not subside within a few miles, then what T-bird said. You can pull the drum to inspect it if you want. Sometimes they come right off, most of the time there is a grove worn into the drum, so you need to back off the adjuster to pull them. Disc brakes often have a wear indicator that squeaks when its time to replace the pads. I don't think the jeep drums have similar wear indicators.
ColdCase is offline
post #6 of 6 Old 10-12-2009, 12:49 PM
T-birdJunkie
2002 KJ Liberty
Nope, and most front brake pads on KJs don't have wear indicators either
Betting the noise has absolutely nothing to do with the car wash, it just happened to show up around then. also, with the age of the brakes...yeah, they only have 62,000 on them, but the lining may be separating from the backing. That's the only reason ThunderbirdJunkie's were replaced at 138,000 miles...
stearing wheel makes a squeaking noise vlad KJ Liberty Forum 16 07-02-2015 03:44 PM
Small Noise in Steering Wheel When You Turn Elt31987 KJ Liberty Forum 5 09-23-2009 10:01 AM
Wheel Noise Liberty15143 KJ Liberty Forum 4 03-11-2009 03:43 PM
Creaking noise when turning steering wheel at a stop? chrispitude KJ Liberty Forum 0 10-29-2005 06:10 PM
Rear Wheel Vibration When Wheel Cranked . . . Cougar Guy KJ Liberty Forum 8 02-22-2005 12:44 PM
