No instrument panel lights - JeepForum.com
post #1 of 4 Old 05-16-2013, 06:34 AM Thread Starter
DarkSport11
2011 KK Liberty
I changed a burned out shift indicator bulb in the center console and it still doesn't light. Yesterday I drove the truck for the first time at night and now my dash doesn't light up either. Everything was fine until I replaced the bulb at the gear selector. I checked the 15 amp fuse and it's good, what else could be causing this all of a sudden?
DarkSport11 is offline
post #2 of 4 Old 05-16-2013, 07:48 AM
Billwill
2002 KJ Liberty
You obviously have tried turning the cluster dimmer switch on the left stalk next to the steering column?
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
post #3 of 4 Old 05-16-2013, 07:54 PM Thread Starter
DarkSport11
2011 KK Liberty
Found the issue and everything is working again including the gear selector light on the console. The owners manual said fuse #34 which is a 15A is for the dash, courtesy and console indicator lamps. When I pulled it was good so just for the heck of it I started to pull out the other fuses and checked them. When I got to #9 cavity and pulled out the 10A fuse it was bad. I found out that 9, 13 and 34 have the instrument cluster and console shift indicator lamp tied into them some way or another.
post #4 of 4 Old 05-17-2013, 01:47 AM
Billwill
2002 KJ Liberty
Great The Owners' manual is notorious for incomplete/incorrect fuse information....you need to check the circuit diagrams for slightly more accurate information.
Billwill is offline
