New liberty owner question - JeepForum.com
post #1 of 24 Old 08-26-2013, 01:32 PM Thread Starter
wingdwolf56
2003 KJ Liberty
Hi everyone,
I just purchased a 2003 Liberty Limited. Like so many preowned vehicles, it didn't come with an owners manual. My question is about 4 wheel drive, part time and full time. It is my understanding that part time locks the differentials and is for short time use in bad traction situations. Full time is for use in changing conditions such as our winter road conditions in northeast Ohio.
Is my understanding of my Liberty's 4 wheel drive correct?
Thanks in advance for any replies.
wingdwolf56 is offline
post #2 of 24 Old 08-26-2013, 04:10 PM
USPLiberty
For the most part yes, "Part time" locks the differential inside the transfer case = snow/offroad use. Fulltime lets the transfer case front and rear differential turn at different rates = patchy, wet/slippery + dry pavement.
USPLiberty is offline
post #3 of 24 Old 08-26-2013, 05:34 PM
tommudd
2004 KJ Liberty
First which transfer case do you have,
that makes a lot of difference in how and when you use 4 wheel drive
MUDD'S MOTORSPORTS
04 KJ JBA 4 INCH COILOVER LIFT
03 KJ JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #4 of 24 Old 08-26-2013, 06:14 PM
olliehopnoodle
1982 FSJ Cherokee
I always get confused in our Liberty. Is 'part time' that is is working 'part of the time' or only use it part of the time. Anyways, your assesment is correct. Full time means you can use it full time. Part time means for low traction situations only. The other way I remember is Full time is marked green, part time is marked red.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #5 of 24 Old 08-26-2013, 06:20 PM
tjkj2002
2002 KJ Liberty
Part time is marked yellow as is 4low.
tjkj2002 is offline
post #6 of 24 Old 08-26-2013, 06:41 PM
tommudd
2004 KJ Liberty
The Liberty is available with either a part-time Command-Trac or full-time Selec-Trac transfer case.
The Command-Trac transfer case has four positions: 2-HI, 4-HI, Neutral, and 4-LO. The lever is placed in 2WD HI for regular driving. This allows the two rear tires to receive power.
The second position, 4WD HI, is used for driving on slippery or loose surfaces only ( not on dry roads or just wet roads. This position locks both the front and rear drive shafts together allowing the vehicle to maintain drive as long as at least one axle has traction.
The third position, Neutral, disengages both drive shafts from the transfer case allowing the car to roll freely; this is used for towing behind another vehicle, for example.
The last position, 4WD LO is used for situations requiring higher torque or slow speed when traversing rough terrain. A common misconception is that 4WD LO provides more traction. It only changes the gear ratio and does not add any more friction between the tires and the driving surface. This position, like 4WD HI locks both the front and rear drive shafts together, and by using a lower gear ratio, allows for 2.72 times more torque (however, the speed is limited to around 25 MPH max). It should be noted that turning while in 4WD HI or LO on dry pavement is hazardous to vehicle components, through driveline binding and wheel-hop.
The Selec-Trac transfer case has five positions: 2-HI, 4-HI Part-Time, 4-HI Full-Time, Neutral, and 4-LO. The transfer case is different from the Command-Trac transfer only in the extra 4WD HI Full-Time position.
The 4WD HI Full-Time position adds the same traction benefits that the part-time 4WD setting offers, but features an open differential between the front and rear axles to allow the two axles to spin at independent speeds and eliminate drive line binding and wheel-hop. The down side of 4WD Hi Full-Time is that, due to the open differential between front and rear drive lines, at times the drive train will only deliver power to the front or the rear e.g. when the front of the vehicle has reached a high traction surface such as dry pavement and the rear is in sand, the rear tires will spin with 100% of engine power, the front receiving no traction. Under equal traction conditions (front-rear) this position gives the rear wheels 52% of the engine's power and the front wheels 48% of the engine's power. The division of power and open center differential allows the Selec-Trac transfer case to be operated at all times in an "All Wheel Drive" mode with no adverse effects.
MUDD'S MOTORSPORTS
tommudd is offline
post #7 of 24 Old 08-29-2013, 02:01 PM Thread Starter
wingdwolf56
2003 KJ Liberty
Thanks for he answers! I have the Select-Trac.
post #8 of 24 Old 08-29-2013, 05:52 PM
95BadBoy
You might want to look in your glove box, there is a skinny slot above the main glove box - that the owners manual resides in.
Worth a look anyhow.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #9 of 24 Old 08-29-2013, 07:24 PM
Leeann_KJ
2005 KJ Liberty
^ what he said. Most people don't know it's there - I 'found' the manuals for both the BIL and CIL (cousin-in-law) just by pulling them out of their slots
Leeann_KJ is offline
post #10 of 24 Old 08-30-2013, 04:54 PM
TomSawyer
2002 KJ Liberty
I have a 2002 ltd 3.7 how do i determine if I have the CT of ST TC?
TomSawyer is offline
post #11 of 24 Old 08-30-2013, 05:07 PM
tommudd
2004 KJ Liberty
Ah,..... well one quick way
*The Command-Trac transfer case has four positions: 2-HI, 4-HI, Neutral, and 4-LO.
The* Selec-Trac transfer case has five positions*: 2-HI, 4-HI Part-Time, 4-HI Full-Time, Neutral, and 4-LO.
MUDD'S MOTORSPORTS
tommudd is offline
post #12 of 24 Old 08-30-2013, 09:21 PM
TwoBobsKJ
TwoBobsKJ's Avatar
2003 KJ Liberty
Hey wingdwolf56 - I'm not far from you in Hartville. I also have an '03 and have the SelecTrac t-case and like you said it comes in handy in the varying road conditions we get around here.
Welcome to the board!
P.S. Listen to what Leann and 95BadBoy said about the owner's manual. Bet you a day-old donut it's right there in the slot above the glove box.
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, ARB Bull Bar, Smittybilt XRC 9500lb Winch, 4X Guard Trans skid, Skid Row Engine skid, Factory T-case & Tank skids, Custom BoulderBars, JBA Front Coilovers, OME 948 rear springs, Bilstein rear shocks, JBA A-Arms, Moabs with Goodyear Duratracs 265/70-16
TwoBobsKJ is offline
post #13 of 24 Old 08-30-2013, 09:24 PM
DeltaForceB85
2008 KK Liberty
"Part time" is not necessarily for "short time" use. If you drive off road through mud and gravel for 12 hours straight, you would use 4-Low the entire time. :-)
-Josh
2008 Jeep Liberty KK W/Selec Trac II, ADL Skid Plate Group, 245/70/16 All Terrain Destinations, VisionX LED Floodlights. It's a real jeep. Don't like it? Wait let me check. Yep, still a real jeep.
DeltaForceB85 is offline
post #14 of 24 Old 08-30-2013, 10:12 PM
tjkj2002
2002 KJ Liberty
In almost 11 years I have never used 4hi(part time) in my KJ,no full time option either.When I go offroad,no matter how long,I'm always in 4low.
tjkj2002 is offline
post #15 of 24 Old 08-31-2013, 01:15 AM
DeltaForceB85
2008 KK Liberty
Whoops read it all wrong. My bad! ;-)
-Josh
