need help, what's 3 bells mean? - JeepForum.com
post #1 of 14 Old 04-12-2010, 07:08 PM Thread Starter
countrygirlie
2007 FSJ Cherokee
i have an 02 liberty and had 3 bells go off as i was driving down the road. i seen somewhere that is he seat belt warning but i had my seat belt on so i know that couldnt be it. does anyone else out there have any idea what it could be. Thanks ahead of time for your help.
countrygirlie is offline
post #2 of 14 Old 04-12-2010, 07:11 PM
kennemore_m
Was there anything in the passanger's seat? If so, the weight could cause the seat belt indicator to go off because it is sensing that someone is sitting there without the seatbelt fastened. Just a thought.
kennemore_m is offline
post #3 of 14 Old 04-12-2010, 08:36 PM Thread Starter
countrygirlie
2007 FSJ Cherokee
There was actually some one in the passanger seat and they had there seatbelt on. So still confused.
post #4 of 14 Old 04-12-2010, 10:59 PM
LibertyTC
2004 KJ Liberty
A message should have appeared either in your digital speedometer, or in the overhead EVIC console if you have one.
LibertyTC is offline
post #5 of 14 Old 04-13-2010, 03:13 AM
2003GCES
Old Man Reminder
The 3 chimes is your turn signal Old Man reminder. You left it on for more than 1 mile. If you have a Evic it says in the display.
2003GCES is offline
post #6 of 14 Old 04-13-2010, 06:26 AM Thread Starter
countrygirlie
2007 FSJ Cherokee
Unfortunately nothing showed in my speedometer and I don't have an overhead evic. As for the turn signal that wasn't it cause it was off and I wasn't even 50 from where I turned. Thanks for the attempts to help though
post #7 of 14 Old 04-13-2010, 06:56 AM
Renegade_Dragon
2016 BU Renegade
Is your washer fluid low?
Cause sometimes when it gets low but not quite low enough, you can set off the chime alert by going down grade (or was it up?). I find it annoying when this happens.
- Excuse the writing, I've got a Dyslexic Keyboard
Renegade_Dragon is offline
post #8 of 14 Old 04-13-2010, 07:04 AM
themadness
i have a 02 lib and to be honest, that sucker chimes for absolutely no reason from time to time. no reason that is obviously present anyway. if it is a mechanical issue it show on speedo or overhead everytime you crank up. may wanna check your backglass when it does it, too. my lifters are weak enough that if accidently hit the button on my remote, it will open but not raise.
themadness is offline
post #9 of 14 Old 04-13-2010, 07:38 AM
Renegade_Dragon
2016 BU Renegade
The hydraulic arms for my rear window recently got to the point where it was doing the same thing.
I'd hit the button to open the window and it would pop open a small amount, but I would physically
have to give it an assist to open it. So a couple of days ago I stopped by Advanced Auto Parts and
purchased two new arms for the window and replaced the old ones.
Now the new arms make a big difference. They were roughly $25.00 apiece, but altogether it was 55.54 with tax
post #10 of 14 Old 04-13-2010, 06:59 PM
2003GCES
OK, The 3 things that have more than one chime are Turn Signal Cancel Warning if driven 3.2k OLD LADY WARNING, Over Speed Warning EXPORT & Head/Park/Fog light-on warning. So take your pick..Hope this help...Believe what I say the blind man seen it to....Chris
2003GCES is offline
post #11 of 14 Old 04-13-2010, 07:02 PM
2003GCES
Mad, Theres chimes for chimes. No read up on it in the Chimes section 8B of the Repair manaul...Chris
2003GCES is offline
post #12 of 14 Old 04-13-2010, 08:31 PM
VoodooMann
2006 KJ Liberty
Could be TPMS if equipped
VoodooMann is offline
post #13 of 14 Old 04-14-2010, 08:00 AM Thread Starter
countrygirlie
2007 FSJ Cherokee
Thanks for all the suggestions people. and yes renegade dragon this is supoer annoying but it turns out it was telling me my coolant levels were off. the one thing i wasnt expecting to happen. just annoyed by nothing showing up on my dash when it happened.
post #14 of 14 Old 04-14-2010, 08:42 AM
Renegade_Dragon
2016 BU Renegade
Now coolant level is one thing I haven't had the misfortune to encounter with my Renny yet.
bells , liberty , warning
