Need help asap please - JeepForum.com
post #1 of 8 Old 07-06-2013, 09:26 AM Thread Starter
alia90
So today i woke up and noticed my front passanger brake hose snapped, and well im not sure how to take it off from the top part. So can anyone tell me how please.
alia90 is offline
post #2 of 8 Old 07-06-2013, 09:33 AM Thread Starter
alia90
I bought the part, and I am ready to replace took off the hose from the caliper part, but cant seem to get it off from the top part connecting to the fluid line. I am not sure how to any help please??
alia90 is offline
post #3 of 8 Old 07-06-2013, 09:41 AM
streetglideok
2005 KJ Liberty
Because of where you live, and the continual use of sodium chloride on the roads, everything rusts badly there. Getting brake lines loose can be a real bear, and I've had to resort to the careful use of an acetylene torch to make them come loose. I've also had to just replace lines as well. Chryslers were always one of the worst for it IMO.
streetglideok is offline
post #4 of 8 Old 07-06-2013, 09:49 AM Thread Starter
alia90
well i checked the lines there fine its the brake HOSE that snapped where the brakes are. heres a few pictures.
alia90 is offline
post #5 of 8 Old 07-06-2013, 09:51 AM Thread Starter
alia90
i wanna no how to disconnect that last part / tube / screw.
alia90 is offline
post #6 of 8 Old 07-06-2013, 10:28 AM Thread Starter
alia90
Bump help pls
alia90 is offline
post #7 of 8 Old 07-06-2013, 11:51 AM
ditch204
The hose should unscrew from the line. Use lots of penetrant and make sure you work the fitting back and forth to release and corrosion. Using a brake line wrench helps a lot by grabbing more of the nut. It kinda wraps around the nut. I just hold the blocky looking part with a vise grip. Jus be careful of to twist the line if it is seized. Hope this helps
ditch204 is offline
post #8 of 8 Old 07-06-2013, 12:12 PM
streetglideok
2005 KJ Liberty
I know what you said, but when you are all said and done, you may be forced into replacing the line too, especially if not careful. You need to be using a high quality flare wrench. As said, visegrips for the block that the line threads into. If you get the fitting to come loose, you must be very careful, as the line is likely corroded to the inside of the fitting, causing it to twist as you turn the fitting. If this happens, you will twist the line off. Only recourse with what you have, is to unscrew the hose block off the line, keeping the fitting still. Screw the new hose on, and tighten it the same way. You may have to manipulate the line to get the hose pointed in the right direction. Its a right hand thread, turn it counter clockwise to loosen it.
