NEED HELP!!! 4x4 or tranny problem - JeepForum.com
post #1 of 5 Old 04-15-2013, 10:55 AM Thread Starter
06libertylimit
2006 KJ Liberty
was shifting out of full time 4 wheel drive back to 2 wheel drive and heard an awful popping/grinding noise coming from underneath the front of the vehicle so i pulled over shifted the 4x4 into neutral and back down to 2-wheel drive now my jeep wont go forward or backward in any gear and it also seems like the 4x4 shifter cable has disconnected. PLEASE HELP... 2006 jeep liberty limited 3.7 liter
06libertylimit is offline
post #2 of 5 Old 04-15-2013, 12:56 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
Some general information from the 2006 KJ Factory Service Manual (FSM):
DIAGNOSIS AND TESTING - TRANSFER CASE - NV242
Transfer case difficult to shift or will not shift into desired range.
POSSIBLE CAUSE - CORRECTION
1) Transfer case shift cable binding. 1) Repair or replace cable as necessary.
2) Insufficient or incorrect lubricant. 2) Drain and refill transfer case with the correct type and quantity of lubricant.
3) Internal transfer case components binding, worn, or damaged. 3) Repair or replace components as necessary.
DIAGNOSIS AND TESTING - TRANSFER CASE - NV231
1) Vehicle speed too great to permit shifting. 1) Slow vehicle and shift into desired range.
2) If vehicle was operated for an extended period in 4H mode on dry surface, driveline torque load may cause difficulty. 2) Stop vehicle and shift transfer case to Neutral position. Transfer case can then be shifted to the desired mode.
3) Transfer case shift cable binding. 3) Repair or replace cable as necessary.
4) Insufficient or incorrect lubricant. 4) Drain and refill transfer case with the correct type and quantity of lubricant.
5) Internal transfer case components binding, worn, or damaged. 5) Repair or replace components as necessary.
JeepCares is online now
post #3 of 5 Old 04-15-2013, 01:19 PM Thread Starter
06libertylimit
2006 KJ Liberty
thanks for the reply i crawled underneath the jeep and found that the plastic gromit that connects the 4x4 shift handle to the transfer case had broken leaving the transfer case in neutral so i hand shifted it back to the 2wd position and all is working fine have the grommit on order now and will replace it when it arrives... however i still need to figure out what would have caused the grinding/popping noise that was accuring after i shifted out of full-time 4x4 mode back to 2wd sounded like it was coming from around both front tires but it only does it when i disengage the 4x4 and it stops after a little while. any advice on what to check or look for would be greatly appreciated!
post #4 of 5 Old 04-15-2013, 05:21 PM
tjkj2002
2002 KJ Liberty
Not fully in 2wd.The select trac t-case is a very touchy t-case to shift.
tjkj2002 is offline
post #5 of 5 Old 04-15-2013, 07:02 PM
TwoBobsKJ
2003 KJ Liberty
X2
Happened to me just the other day. I had it in Full Time 4WD (I do that about once a month just to keep things lubed up) and when I went to back out of a parking spot after shifting it back to 2WD it was all bound up. Shifted it into Drive and Reverse a couple of times before it dropped back to 2WD.
I know the 242's quirks but it will still get me sometimes...
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, ARB Bull Bar, Smittybilt XRC 9500lb Winch, 4X Guard Trans skid, Skid Row Engine skid, Factory T-case & Tank skids, Custom BoulderBars, JBA Front Coilovers, OME 948 rear springs, Bilstein rear shocks, JBA A-Arms, Moabs with Goodyear Duratracs 265/70-16
TwoBobsKJ is offline
4x4 not working , drivetrain , tranny problem
