Is my power steering going? - JeepForum.com
post #1 of 8 Old 07-10-2013, 08:23 PM Thread Starter
MemphisJeepDude
Lately (naturally, right after I dropped $800 on new brake pads/rotors/calipers), my 2005 Liberty Sport 3.7L has made a whining noise when turning at low speed, both forward and reverse. This seems like a power steering issue, no? How much would something like this set me back? The car has 122k miles, so not sure how much its worth it to put a bunch of money into it again
MemphisJeepDude is offline
post #2 of 8 Old 07-10-2013, 09:01 PM
oilbuner
2006 KJ Liberty
The "whining" is the classic sign of low fluid. CK it out, you might get 2-3 qts and flush the system to get rid of the old burnt fluid. Hopefully you caught this in time before the pump gave out from lack of fluid. Oilburner
When the pavement ends, you better have some ground clearance!
oilbuner is offline
post #3 of 8 Old 07-11-2013, 01:30 PM Thread Starter
MemphisJeepDude
I bought some fluid at AutoZone the other day (http://www.autozone.com/autozone/acc...equestid=84164) but I can't for the life of me find the place to put it! The manual shows where it is on the 2.8L engine, but not on the 3.7L. Also, not sure if I bought the right kind of power steering fluid.
Any thoughts?
post #4 of 8 Old 07-11-2013, 02:00 PM
95BadBoy
ATF+4 is the proper power steering fluid if memory serves me today.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #5 of 8 Old 07-11-2013, 04:43 PM
jbarthol
2005 KJ Liberty
And if my memory serves me right, the resevoir is between the engine and battery/fusebox (a bit hidden, but it should be there). I also believe it is ATF+4.
jbarthol is offline
post #6 of 8 Old 07-11-2013, 05:33 PM
Luke09
2005 KJ Liberty
yup just a little bit forward of that area ... ATF+4 is correct!
2005 Liberty Renegade - Dark Khaki
Frankenlift IIP, Mobil1 Synth.& Filter, PIAA Extreme White, Amsoil EA Filter, Spidertrax 1.25, 245/75/16 Duratracs
Luke09 is offline
post #7 of 8 Old 07-11-2013, 07:56 PM Thread Starter
MemphisJeepDude
Is the fluid I got not ATF+4? It doesn't say anything on the bottle or at the link
post #8 of 8 Old 07-11-2013, 10:31 PM
jbarthol
2005 KJ Liberty
Usually if it has Prestone on it, I generally avoid it. Link is what I usually use.
http://shop.advanceautoparts.com/web...chTerm=atf%2B4
jbarthol is offline
