Is my 2003 dead? - JeepForum.com
post #1 of 10 Old 05-30-2014, 03:42 PM Thread Starter
Anoon
2003 KJ Liberty
Is my 2003 dead?
3.6L V6 manual. Multiple cylinder misfires and #2 misfires. There is a ping/knocking noise from the engine that I can also feel in the gas pedal. #2 does hold compression. Thoughts?
Anoon is offline
post #2 of 10 Old 05-30-2014, 06:56 PM
tommudd
2004 KJ Liberty
have you pulled the spark plug yet or tried anything?
04 KJ WITH JBA 4 INCH COILOVER LIFT
03 KJ WITH JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #3 of 10 Old 05-30-2014, 08:38 PM
02blue
2002 KJ Liberty
Pull the "valve" cover and see if you threw a rocker from #2.
"Hey, ya never know til you try." Kurt Russell-Big Trouble in Little China
02blue is online now
post #4 of 10 Old 05-30-2014, 10:42 PM Thread Starter
Anoon
2003 KJ Liberty
I pulled the ignition coil and spark plug. Both are fine. I will pull the valve cover tomorrow. I was thinking rocker or even timing chain.
Anoon is offline
post #5 of 10 Old 05-31-2014, 07:17 AM
02blue
2002 KJ Liberty
I threw a # 2 exhaust a while ago. Fell out of the way but wicked misfire. Popped it back on and has been fine since.
post #6 of 10 Old 06-03-2014, 03:24 PM Thread Starter
Anoon
2003 KJ Liberty
#2 threw an arm. Getting new lifters and piecing it back together.
Anoon is offline
post #7 of 10 Old 06-05-2014, 08:37 AM
olliehopnoodle
1982 FSJ Cherokee
Can you get the arm back in without compressing the spring? If you can, you have probably dropped the #2 valve seat. These are notorious for doing this on that valve.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #8 of 10 Old 06-05-2014, 03:55 PM Thread Starter
Anoon
2003 KJ Liberty
I could not get it back in. The lifter was totally seized. With the new lifter, I had to depress the spring to get it back in place.
Anoon is offline
post #9 of 10 Old 06-09-2014, 07:34 PM Thread Starter
Anoon
2003 KJ Liberty
Got it put back together. Still has an awful shake and it won't stay running at idle. There is now a PO 0155 code, which comes up as an O2 sensor. It will now be parted out and the carcass will be scrapped.
Anoon is offline
post #10 of 10 Old 06-09-2014, 10:18 PM
02jeepliberty
What trim level is it? Sport?
02jeepliberty is offline
