multifunction or headlamp switch? - JeepForum.com
post #1 of 8 Old 10-16-2010, 01:55 PM Thread Starter
jamesdart
when i turn the steering wheel to switch lanes sometimes my interior lights come on. the other mornign i was driving to work and my headlampos cut out 3 times on me. i could hear the relay operating.
jamesdart is offline
post #2 of 8 Old 10-17-2010, 04:15 PM
richd
2008 KK Liberty
Multifunction switch controls the headlights,so I would say the multifunction switch is bad.
richd is offline
post #3 of 8 Old 10-18-2010, 02:30 AM
AndyTee
2002 KJ Liberty
I havea 2002 Cherokee (Liberty in the USA) and have a very similar problem. The interior light also comes on sometimes when I change from low to high beam and vice-versa. I also note that my dash illumination is always dark and if I rotate the collar on the indicator stalk the interior light comes on too.... Sometimes the interior lights come on just driving along and when i twist the dash illumination control to the lowest setting they go off.
Feedback from this and other Jeep forums points to the indicator stalk on the left needs replacing however this appears to be a combined unit with both left and right stalks being a single part together. I have bought a used unit and will fit in about a week when I get home from this rig and figure how to change it without setting off the airbag
Let us know how you get on with this as its a most annoying problem.
Have fun
AndyT
AndyTee is offline
post #4 of 8 Old 10-18-2010, 06:25 AM
tjkj2002
2002 KJ Liberty
It takes about 10mins to change the multifuction switch in a KJ,no airbag removal required.
tjkj2002 is offline
post #5 of 8 Old 10-18-2010, 07:14 AM
AndyTee
2002 KJ Liberty
Thats the best news I've had in a while. Can you describe briefly how to go about this as I don't have a Manual for the car as yet. I've looked on various places and can't find any info as yet.
Many thanks in advance
AndyT
AndyTee is offline
post #6 of 8 Old 10-18-2010, 07:35 AM
tjkj2002
2002 KJ Liberty
AndyT
Just need to take off the steering column covers,like 3-4 screws(on the bottom cover),after those are removed it's only like 2-3 bolts that hold on the multifuction switch.
tjkj2002 is offline
post #7 of 8 Old 10-22-2010, 01:52 PM
AndyTee
2002 KJ Liberty
:-( still have issues with the interior lights...
Well I changed the multifunction switches for another set and as tjkj2002 says its very easy to do with just 2 screws to come out from under the steering wheel to remove the panels and the multifunction switch just lifts out. The screws have a Torx type head on them though so a normal screwdriver or allen key won't work, luckily I have a full set of torx keys.
HOWEVER - I changed it over for a much newer switch from a 2005 car which looks identical and the issue is still there :-( In fact the front fog lights come on as soon as I put the side lights on now so either its a duff multi function switch or they changed the pin connections from 2002 to 2005 which sounds unlikely as all the functions are the same. I also note I am getting the "glass" warning coming up so need to look at the wiring to that and the switch itself. Does anyone know how is the best way to get to the glass closed switch, is it just by removing the rear tailgate door trim panel off or something more difficult.
Many thanks in advance.
AndyT
AndyTee is offline
post #8 of 8 Old 10-23-2010, 01:07 PM
AndyTee
2002 KJ Liberty
Just a quick update - I read through all teh online manuals from the link on this site and got more convinced my fault lay with the flip up glass warning switch. As this switch is normally open when the glass is closed I just removed the trim from the tailgate and disconnected the switch at the local connector and hey presto everything works fine. Apparently the switch isn't seviceable on its own and I don't fancy ******* out more for a new one so its just been left disconnected, I can't imagine me forgetting teh glass is up living in Scotlans as its freezing here
Next jobs now are te ABS sensor light comes on intermittantly and the cruise control isn't as smooth as i feel it should be.
I even go the code fr my radio so another result Time to chill with a few beers for the night.
AndyT
AndyTee is offline
Guide to changing headlamp bulbs in 2005 Liberty? AVR2 KJ Liberty Forum 11 01-11-2017 09:41 AM
CRD ORM Switch? KhakiCRD KJ Liberty Forum 0 11-02-2008 01:32 AM
Multifunction Instrument Light kaffirkicker KJ Liberty Forum 3 01-28-2008 01:46 PM
Lib 02 heater/ac fan switch Dirtnapper KJ Liberty Forum 7 07-16-2006 02:05 AM
Headlamp Bulb Replacement Rucky KJ Liberty Forum 3 01-21-2005 12:36 PM
