Manual Reverse - JeepForum.com
post #1 of 5 Old 10-16-2006, 01:30 AM Thread Starter
drose2
Manual Reverse
I have an '05 Libby sport, with a manual transmission. It seems to grind gears in reverse : . Has anyone had this problem?
I have driven a stick for years and don't think I have burned a clutch after 16,000 miles.
drose2 is offline
post #2 of 5 Old 10-16-2006, 06:24 AM
m90daytona
mine doesnt grind going into reverse try holding in the clutch for 5 seconds and then putting it in reverse. i know my old cherokee had this problem. if you went to put it in reverse immediately it would grind but if i held the clutch in for 5 seconds and then put it in reverse it was fine.
or push the clutch in, put it in first, and then put it in reverse w/out letting the clutch out in between. this works well too. i think it has something to do w/ the input shaft still spinning when you push the clutch in.
m90daytona is offline
post #3 of 5 Old 10-17-2006, 04:37 PM
GaryL06
My old cherokee used to do that all the time, too. Eventually the tranny siezed and I wrecked it.
Have you check the fluid level? Do you park for prolonged periods of time on a hill?
GaryL06 is offline
post #4 of 5 Old 10-17-2006, 08:07 PM
TJJIM79
Some vehicles that I have driven in the past with a manual trans, seemed to go into reverse easier if you put it into first gear first and then into reverse. Don't know if this will work but it is worth a shot.
TJJIM79 is offline
post #5 of 5 Old 10-17-2006, 09:09 PM
m90daytona
thats what worked on my cherokee.
problems with reverse babes66 KJ Liberty Forum 4 11-12-2008 04:26 PM
Reverse? flair1111 KJ Liberty Forum 7 02-02-2007 05:07 PM
Does 4WD work in reverse? spamloverman KJ Liberty Forum 8 02-17-2006 02:05 PM
Weak Reverse Ghostrider KJ Liberty Forum 2 10-10-2005 09:22 AM
4Hi in reverse drossia KJ Liberty Forum 7 01-22-2005 03:46 PM
