lug nut torque spec... - JeepForum.com
post #1 of 14 Old 05-01-2007, 05:51 AM Thread Starter
matr8er
In the manual they state to use 85-110 foot pounds of torque on the lug nuts. I would like to know what it should be, or what the experts say it should be. 85-110 still leaves a lot of guess work. I know it is pretty important to get the torque right, but what does a wrong torque cause? I got new McGard lugs and torqued them to 102 foot pounds. within the specs. Any info would be helpful. Thanks!!!
matr8er is offline
post #2 of 14 Old 05-01-2007, 06:15 AM
festerw
festerw's Avatar
I usually do 100-105 on all my vehicles.
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is online now
post #3 of 14 Old 05-04-2007, 05:19 PM
Flynjp
2011 JK Wrangler
Incorrect torque (too much) can warp brake rotors and screw up aluminum rims. I set my torque wrench to 100 ft/lbs.
Flynjp is offline
post #4 of 14 Old 05-04-2007, 09:00 PM
jeepjeepster
100ft lbs..
jeepjeepster is offline
post #5 of 14 Old 05-06-2007, 08:26 AM
JJsKJ
2003 KJ Liberty
I also go w/ 100 ft lbs on a good quality torque wrench.
1999 TJ
JJsKJ is offline
post #6 of 14 Old 05-08-2007, 09:41 AM
indianrefining
The "85-110" in your manual is what is known as a "compound torque". It does not mean "somewhere between 85 and 110 foot pounds". It means that you are supposed to first torque all 5 lugs (in the proper sequence) to 85 foot pounds and, then, re-torque them to 110 foot pounds. This is pretty much standard procedure with composite rims. It allows for a more gradual tightening in order to obviate fracturing the rims.
indianrefining is offline
post #7 of 14 Old 02-10-2013, 02:14 PM
2Jeeps1Cup
2008 JGC user manual, page 391, "Correct wheel nut tightness is 95 ft-lbs (130 N-m.)
Just thought I'd toss that one out there for anyone who needs it!
cheers
2Jeeps1Cup is offline
post #8 of 14 Old 02-10-2013, 05:31 PM
tjkj2002
2002 KJ Liberty
cheers
To bad this is not the Grand Cherokee section and it's 85-115lbs-ft for a KJ.
tjkj2002 is offline
post #9 of 14 Old 02-10-2013, 05:59 PM
01CHEEKEE
I turn the 4 way til I can't turn it anymore, same way it's been done for like 70 years or so
01CHEEKEE is offline
post #10 of 14 Old 02-10-2013, 08:12 PM
tjkj2002
2002 KJ Liberty
That's a sure way of stretching the wheel studs.
Torque wrenches have been around just as long as lug nuts.
tjkj2002 is offline
post #11 of 14 Old 05-01-2014, 06:33 AM
maralin49
2008 MK Compass
torque settings
Hello all, Can anyone tell me the torque settings for the bolts on the rear suspension i.e. upper and lower control arms, toe link bars, toe link stabilising bars, struts.
Any help would be invaluable.
Thanks
maralin49 is offline
post #12 of 14 Old 05-01-2014, 02:21 PM
remmons
Plus keep in mind, when you tighten them to spec you really should practice the every other wheel stud method, i.e. #1, #3, #5, #2, and then #4 (in a star-like pattern). This also prevents mistorque, and the possibility of cracked rims.
Robert.
remmons is offline
post #13 of 14 Old 05-01-2014, 03:17 PM
AVR2
I know this is an ancient thread, but indianrefining's comment about the lug nuts requiring a "compound torque" doesn't square with anything I've ever read in a FSM.
If you're supposed to torque to one figure, and then another, the FSM will always say so, clearly stating "Step 1 torque", "Step 2 torque" and so on. It doesn't do this for the lug nuts, and it doesn't specify a nut tightening sequence either.
I've always just picked about 100 ft lbs, and tightened in a star pattern, starting wherever I feel like. Never had a problem.
AVR2 is online now
post #14 of 14 Old 05-01-2014, 08:17 PM
95BadBoy
Yah, that's pretty close to how I set mine. I know I'm old fashion, but I still don't air gun mine either (ever) to take off the lugs. Plain old torque wrench does the job just fine putting 'em back on. Never had any issues, never broke a stud.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
2.8 CRD oil spec Janandoug KJ Liberty Forum 3 01-19-2010 09:58 AM
Anyone know proper torque spec for front prop shaft on 05 Rafikie KJ Liberty Forum 3 01-06-2010 04:35 PM
2008 3.7L, Need Torque Spec for Oil Pressure Sending Unit gregk001 KJ Liberty Forum 3 09-05-2009 11:17 AM
Spec sheets 95jeepzj KJ Liberty Forum 6 10-07-2007 09:44 AM
Spark plug torque spec? Jakked KJ Liberty Forum 4 07-07-2007 05:40 AM
