Low line pressure - JeepForum.com
post #1 of 3 Old 09-23-2013, 10:44 PM Thread Starter
chriscrook
2001 KJ Liberty
Low line pressure
Hi I have a Jeep liberty 2001 with the 45rfe auto box. Could dirty oil/filters cause the aouto box's low line pressure warning to show ? I took it to a private jeep workshop who said the oil was fine. He also plugged it into a computer and ran some kind of test on it which caused a lot of loud clanking as it changed gears which he said would tighten up/reset the gearbox ?. To me it sounded more like seriously stressing the gear box, any thoughts. He also said low line pressure in the aouto box is a common problem and not to be too concerned. Currently it is on 50,000 miles and the gear oil has never been changed. I have also been told it is not a good idea to change the gearbox oil unless absolutely necessary as doing this can cause problems
chriscrook is offline
post #2 of 3 Old 09-24-2013, 06:13 AM
tommudd
2004 KJ Liberty
Should of been done, if you have 50,000 miles on it, I would go to the dealer and have it flushed and be good for a while.
Now if you had 150,000-175,000 then I wouldn't touch it
But a dealer is the only one who uses the correct fluid when flushing them
MUDD'S MOTORSPORTS
04 KJ JBA 4 INCH COILOVER LIFT
03 KJ JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #3 of 3 Old 09-25-2013, 08:52 AM Thread Starter
chriscrook
2001 KJ Liberty
Hi Thanks for the feedback
