Losing tire pressure in low temps - JeepForum.com
post #1 of 4 Old 02-17-2006, 02:22 AM Thread Starter
Bighaeb
Bighaeb's Avatar
What's the deal? The wife's Liberty renegade is losing tire pressure from 32 all the way down to 10 every time it gets below around 20 or so in temp. This has happened a number of times now. Just one tire does it. I got a compressor so we can deal with it for now. No one can seem to find a leak when submerging in a tank or even doing the soap sud trick. Any clue? Anyone else had this happen?
"Rigged for her pleasure"
Jeepless for now
Bighaeb is offline
post #2 of 4 Old 02-17-2006, 07:51 AM
hyedipin
hyedipin's Avatar
down to 10? that's too much.. guessing that your area temp does not differ 80 degrees from night to morning..
Get it checked elsewhere (no one can find the hole?)..
Probably a spike or something letting air get away.. no big deal, really, but 10? that's way too low.
Another suggestion. Spit on the air valve, see if it bubbles
hyedipin is offline
post #3 of 4 Old 02-17-2006, 11:03 AM
gerrya
gerrya's Avatar
Usually after checking the tire for nails I tighten the valve core. Ive checked valve cores with leak tech and it showed no leak, but after tightening it anyways it stops.
gerrya is offline
post #4 of 4 Old 02-17-2006, 04:00 PM
wild_weazel
wild_weazel's Avatar
Sounds like my problem. I had a bad rim when it got cold it was to porus (sp). I spent 2 winters trying the dunk thing at a dealership. I finally brought it to a different dealership I told them my problem and told me to let them try it there way first if it didn't work then they would order me a new rim (on warranty of course). They did the dunk thing cleaned the bead and checked it for nails etc... Well guess what it didn't work. I brought it back to them and let them see it overnight. I put the bad tire on the tailgate and told them it was flat. I let them fill it with air and let it sit overnight. The next morning they came in and it was flat. Needless to say about 6 days later I had a new rim and no more leaks.
Don't let them keep doing that damn dunk test. You know that there is nothing wrong with the tire. Make them get you a new rim. I think DC might of had a bad batch of rims. I've only heard of this on the Reny's though. Do a search and you wil see this has been brought up a few times. I think I'm on every post. Goodluck
1990 Jeep YJ, Olivine Green, SBC 350, 700r4 Tranny, NP231C Transfercase, Painless Wiring, Superlift 3.5" Lift 5/8" M.O.R.E. Shackles, 33" tires. Dana 44's front and rear 4:10 gears, And a Whole lot of Money
wild_weazel is offline
Tire Pressure Sensors For Kk palaz KJ Liberty Forum 9 10-31-2009 12:05 AM
Fluctuating Temps Jeepson33s KJ Liberty Forum 1 07-31-2009 05:46 PM
Change Tire, Tire Pressure Monitor Location? Valkraider KJ Liberty Forum 1 01-12-2006 01:35 PM
tire pressure KMBANDcom KJ Liberty Forum 18 11-03-2005 08:46 AM
Tire Pressure? Patrick Bateman KJ Liberty Forum 8 10-10-2005 10:12 AM
