Losing power in 3rd? - JeepForum.com
post #1 of 13 Old 05-05-2011, 06:15 PM Thread Starter
mdreher
I just purchased an '06 Liberty Limited w 58k miles. It looks great and runs great, but I have noticed that it loses power while accelerating in 3rd gear. I'll be accelerating and right around 2000-2500 the rpms just drop down to 1500rpm. I'm a little confused to what could be happening to cause this. If I give it enough gas it downshifts and I'm fine, but it just doesn't feel right. I've never had a vehicle that would just stop accelerating like that. Any ideas? I checked the air filter and it's clean and I'm pretty sure it doesn't have a fuel filter that could be dirty.
mdreher is offline
post #2 of 13 Old 05-05-2011, 06:39 PM
jaarr76
2007 KJ Liberty
Over drive mine does the same. I turn it off all the time.
2007 KJ Frankenlift II Baja JBA 4.5 UCAs
jaarr76 is offline
post #3 of 13 Old 05-06-2011, 10:34 AM Thread Starter
mdreher
I've tried turning that off when it begins losing power, bu it doesn't seem to change things. I'll try it again prior to losing power and see how that affects it.
mdreher is offline
post #4 of 13 Old 05-07-2011, 07:48 AM Thread Starter
mdreher
It seems like everyone is saying overdrive and that it's acting normal, but it's happening around 30mph to 40 mph repeatedly. I'm no Jeep expert, but I'm assuming that they wouldn't have made such a poor design. It kind of defeats the V6. Is there anything else that could be happening?
mdreher is offline
post #5 of 13 Old 05-08-2011, 12:23 PM
jaarr76
2007 KJ Liberty
Mine does it around 40 mph. It shifts into over drive it's a very dramatic change like it's geared to high. I asume that's just the way it is.
jaarr76 is offline
post #6 of 13 Old 05-08-2011, 07:43 PM
LibertyTC
2004 KJ Liberty
Look at the overdrive as an RPM limiter for fuel economy. This works fine on level ground on highway for maintaining a low RPM and good fuel economy. The problem is that enter in the wieght of your KJ and passengers, and try to hill climb, with overdrive on. It will bog out and the downshift comes on too late to rescue your speed up the hill.
Before the hill, I take the overdrive off and try to get the speed up enough, so It does not bog out in the middle of the hill. Practice getting some power on with overdrive off and you will see what I mean.
Large long steep mountain hills often require 2nd gear and hopefully not to the floor. The KJ is heavy and when I pull boat you feel like you may end up going backwards up mountain. It is not the most powerful thing for pulling. I prefer V-8's for that work, but it can do it.
Many with larger tires re-gear front and rear diff's with 4:10s so the powerband is more usable.
LibertyTC is offline
post #7 of 13 Old 05-09-2011, 03:08 PM Thread Starter
mdreher
Thanks for insight everyone. It's good to know nothing is actually wrong.
mdreher is offline
post #8 of 13 Old 05-10-2011, 04:38 PM
Powerslave
2006 KJ Liberty
Mine does this too, it's the Torque Converter Clutch locking up... I am currently trying to place a switch to disable it. I have done it in other vehicles, just not sure where on this one. IT makes for a nice Tow/Haul setting, but make sure you have a good transmission cooler.
Powerslave is offline
post #9 of 13 Old 06-10-2011, 06:23 PM Thread Starter
mdreher
I decided to take everyones word and accept that it was just a libby thing, but then one day I was parked and idling and the rpms started hunting a little. They dropped to around 500 rpm and then jumped to 1100 rpm. They would settle out around 700 and then do it again. After the 3rd or 4th time the engine stalled. The lack of power while accelerating is happening slightly more and I just don't think it's a libby thing anymore. I've changed the plugs and seafoamed it, but that didn't do anything. Could I have a bad sensor of some type?
mdreher is offline
post #10 of 13 Old 06-10-2011, 08:15 PM
Opticalx007
2006 KJ Liberty
Yes it could be any number of sensors going or gone bad... One you should check first is the mass air flow sensor... If you are running an oiled air filter that may be your problem, a dirty mafs... Try that first and see what happens...
Opticalx007 is offline
post #11 of 13 Old 06-11-2011, 10:01 AM
Powerslave
2006 KJ Liberty
There is no MAF!
RPM hunting is usually a bad TPS.
I am running an Oiled Air filter, it is not the problem.
post #12 of 13 Old 06-15-2011, 10:26 AM
50rck
I think there is a write up about it in the manual. I was worried about it when I bought my '06 as well (purchased 12-2010).
1991 YJ, rebuilt 4.0L in spring 2009 at 234,000 miles, no lift yet, slightly offset wheels, 235/75/15 tires for now, rag top, sold the hard top. Over 35,000 miles on the rebuild and counting.
2006 Jeep Liberty. Nothing special, all stock.
50rck is offline
post #13 of 13 Old 08-05-2013, 01:23 PM
spittingglass
2006 KJ Liberty
Was there ever a definitive answer to this? I'm having the exact same issue with the same model year, right down to the dropping to ~1500rpm. Generally occurs once hitting the 35mph mark/3rd gear. Overdrive on/off makes no difference.
spittingglass is offline
2002 Liberty Sport 3.7 losing water libertync KJ Liberty Forum 0 04-25-2011 07:17 AM
Power Steering Fluid Change or Power Steering Noise READ THIS 2003GCES KJ Liberty Forum 6 04-13-2010 03:27 AM
need more power liberty_tank KJ Liberty Forum 4 04-07-2009 10:23 PM
losing coolant wvebert KJ Liberty Forum 1 10-23-2008 10:12 AM
Losing tire pressure in low temps Bighaeb KJ Liberty Forum 3 02-17-2006 04:00 PM
