Looking for wiring diagram (2002 liberty) - JeepForum.com
post #1 of 6 Old 12-28-2004, 06:25 PM Thread Starter
invo
If anyone knows where I could get these (wiring diagrams) in downloadable format, I would really appreciate it. I'm about to install a remote car starter (Automatic) and would rather not play trial and error!
invo is offline
post #2 of 6 Old 12-29-2004, 04:41 PM
02KJSport
Just warning you ahead ahead of time unless you really know what you are doing (certified) I really wouldn't take this one on. Even if you have installed a couple before, just letting you know that the Liberty is a good bit more difficult than most.
Install requires a relay (simple enough) and diode/resistor isolating wires. It could be very easy to mess something up.
That being said here is what I used for my 2002 Sport. Just test every wire before cutting.
|......ITEM.................|.....WIRE COLOR.....|POL|.......WIRE LOCATION
| 12V........................|red & pink/black.....|+ |......ignition harness
| STARTER ................|yellow..................|+ |......ignition harness
| IGNITION.................|red/blue...............|+ |......ignition harness
| ACCESSORY.............|black/orange.........|+ |......ignition harness
| 2nd ACCESSORY.......|black/white...........|+ |......ignition harness
| POWER LOCK............|pink/purple *1.......| - |......back of fusebox *2
| POWER UNLOCK........|same wire.............| |
| LOCK MOTOR............|orange/black.........| |......back of fusebox *2
| UNLOCK MOTOR.......|pink/black..............| |......back of fusebox *2
| DISARM DEFEAT.......|orange/purple.........| |......back of fusebox *2
| PARK LIGHTS +........|DO NOT USE..........| |
| PARK LIGHTS -.........|lt. green/orange *3.| |......headlight switch
| HEADLIGHTS............|same wire *3........| |
| DOOR TRIGGER.........|*4......................| - |......right of st column,blue plug
| DOME SPRVISION...|use door trigger.......| |
| HATCH PIN...............|tan/black *7........| - |......conn. 1, pin 7 @ BCM *6
| HOOD PIN................|brown/tan............| - |......conn. 1, pin 6 @ BCM *6
| HATCH RELEASE.......|orange/pink...........|- |......conn. 1, pin 17 @ BCM *6
| FCTRY ARM..............|...........................| |
| FCTRY DISARM.........|lt. green/orange *5..|- |......conn. 2, pin 9 @ BCM *6
| TACHOMETER..........|NOT grn/or or or/grn..| |......ign coil, coil pac, injector
| SPEED SENSE.........|lt green/yellow..........| |......conn. 1, pin 20 @ BCM *6
| BRAKE WIRE...........|white/tan...............|+ |......brake pedal switch
| HORN TRIGGER........|black/red...............|- |......steering column
| WIPERS.................|brn/wht(L),rd/yel(H).|+ |......wiper motor
| LF WDW UP/DN......|lt blue - white..........|A |......center console window switch
| RF WDW UP/DN......|brown - pur/wht.......|A |......center console window switch
| LR WDW UP/DN......|red/blk - blu/wht.......|A |......center console window switch
| RR WDW UP/DN......|grn/wht - gry/blk.......|A |......center console window switch
| SUNRF OPN/CLSE....|not recommended......| |
| RADIO 12V.............|pink.......................|+ |......radio
| RADIO GROUND.......|black.....................| - |......radio
| RADIO SWITCH.......|orange/red.............|+ |......radio
| RADIO ILLUMIN.......|orange (dimmer)......|+ |......radio
| LF SPEAKER...........|green - brn/red.......| |......radio *8
| RF SPEAKER...........|purple - blu/red.......| |......radio *8
| LR SPEAKER...........|brn/yel - brn/lt blu...| |......radio *8
| RR SPEAKER...........|blu/wht - blu/org.....| |......radio *8
Note : Gray ignition key uses immobilizer system. Use DEI part number 555U.
1 Lock - trigger w/ 1.4K Ω resistor, unlock - trigger w/ 426 Ω resistor. Use DEI 451M relay.
2 In the top left corner in a black plug.
3 Park light - trigger w/ 910 Ω resistor. Headlight - trigger w/ 349 Ω resistor. Use relays.
4 Drvr door trigger tan, pass'er door trigger tan/white, use both wires, diode isolate each.
5 The factory alarm disarm is - trigger w/ 473 Ω resistor. MUST use relay.
6 BCM attached to left of fusebox. Connector 1 gray 26 pin plug, connector 2 gray 22 pin plug
7 The flip up glass pin switch is yellow/white in conn. 1, pin 9 of the BCM.
8 On vehicles with the premium sound system, each speaker is individually amplified.
......................___________
......................|.....451M....| Relay for Connecting to Lock\Unlock
......................|.....Relay....|
......................|__________|
......................| | | | |_____ Brown Do Not Use
......................| | | |_______ White Do Not Use
......................| | |_________ Purple to Ground
........Grn\Blk-->| |<--Blu\Blk
1.4KΩ Resistor>| |<426Ω Resistor
______________|_|________Pink\Purple Wire
02KJ Sport
02KJSport is offline
post #3 of 6 Old 12-29-2004, 11:31 PM Thread Starter
invo
Thanks, exactly what I needed. Thanks for the warning too. I'm still a little unsure of the location of that Tachometer wire tho.
invo is offline
post #4 of 6 Old 08-29-2011, 07:50 PM
iceman72
Help
I have my radio hooked up. All my wires are used on the radio side. But the orange wire is solo. Now I am getting a NO Bus error. Is this because of the orange wire not being hooked up to something?
iceman72 is offline
post #5 of 6 Old 08-30-2011, 05:20 AM
Billwill
2002 KJ Liberty
If you do a search on this forum for "Liberty Service Manuals" you will see a link to download the manuals for 2002 Liberties. Download section 8, Electrical drawings...about 42 Mb.
This gives you all the diagrams for the 2002 KJs, gas or diesel, USA or Export, LHD RHD etc.
It also gives you an overview of most components and locations and fault finding etc.
Billwill is offline
post #6 of 6 Old 03-18-2012, 07:41 AM
iceman72
I finally found the issue and got it working.
iceman72 is offline
2002 Liberty wiring diagram? Mudviper KJ Liberty Forum 1 12-09-2009 07:10 PM
need wiring diagram help 2002jeepliberty KJ Liberty Forum 1 06-13-2009 11:56 AM
Need Fuse Box Diagram for 03 Liberty RAAB3485 KJ Liberty Forum 0 09-22-2006 11:45 PM
Wiring Diagram silver_2000_TJ KJ Liberty Forum 2 12-22-2005 06:21 PM
Wiring diagram for Liberty Mad Mechanic KJ Liberty Forum 1 01-22-2005 08:08 PM
