lifting my 2003 liberty - JeepForum.com
post #1 of 7 Old 08-29-2009, 09:40 PM Thread Starter
ssled07
I want to lift my 2003 Liberty Renegade. I was looking at the 2.5" frankenlift, which seems like a good lift, but i want to go higher. Would it be possible to buy the frankenlift, put it on and get the rock krawler 3.5" X Factor System and use the front strut forksin the rock krawler kit, replacing the original ones and then putting the spring spacers in the rock krawler kit under the rear coil springs that come in the frankenlift kit? Would the 2 lifts work together? Just an idea
ssled07 is offline
post #2 of 7 Old 08-29-2009, 10:33 PM
jsc7002
1966 CJ5
No!! The Frankenlift is the biggest you can get, Jeepin By Al sells a 4" and a 6" but really you cant go past 32" tires on the KJ bc the front diff is aluminum any bigger and you bust it, if you really want bigger you need to do a SFA which will run you about $5000 atleast.
jsc7002 is offline
post #3 of 7 Old 08-29-2009, 10:39 PM Thread Starter
ssled07
oh wow okay. So do you think the frankenlift is a good one to get?
ssled07 is offline
post #4 of 7 Old 08-30-2009, 10:43 PM
djui5
2004 KJ Liberty
The Frankenlift and the OME lift are the best 2 lifts u can get. 2.5" is enough to do some "hardcore" wheelin with a Liberty. Trust me
Randy Wright,
Apache Junction, Arizona
2004 KJ lifted/etc
1974 CJ-6 being restored
djui5 is offline
post #5 of 7 Old 08-30-2009, 10:58 PM Thread Starter
ssled07
awesome. thanks for the advice
ssled07 is offline
post #6 of 7 Old 08-31-2009, 08:52 AM
95BadBoy
ssled07
One thing, many KJ's have a good amount of front and rear suspension sag after a few years. When you do something like the Franky lift (nice lift by the way) - you will most likely yield more than the 2.5". Thier lift brings you to 2.5 over stock highth. There is a good chance you could be at 3 to 4" - depending at where your saggy suspension is at now. FWIW
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #7 of 7 Old 08-31-2009, 07:38 PM
jsc7002
1966 CJ5
The Frankenlift uses OME parts but they just add a spacer to make it a little high then just OME coils but you can make your own Frankenlift by add a clevis lift and strut plate but then you have to add your longer bumpstops and if you go real high like that its best to also get some JBA upper arms bc they are made for KJs with a lift and are greaseable and replaceable whereas the stock ones arent
jsc7002 is offline
Lifting a 2009 liberty 2000jeeper KJ Liberty Forum 11 07-08-2009 07:26 AM
Lifting a Liberty and the consequences chaser KJ Liberty Forum 1 04-05-2009 02:31 PM
08 Liberty & Lifting it testedone KJ Liberty Forum 2 06-15-2008 06:39 PM
Lifting a Liberty froosa KJ Liberty Forum 7 08-23-2007 06:45 AM
Lifting a Liberty myrtlebeachjeep KJ Liberty Forum 1 07-29-2007 07:02 PM
