lifted now getting banging noise - JeepForum.com
post #1 of 8 Old 06-06-2013, 10:20 PM Thread Starter
RogueKJ
2004 KJ Liberty
Just lifted 04 liberty 2.5 day star brand new Moog coils. Getting banging noise in front over bumps. Driver tire rod has a little play in it. Front axles I can move by hand up an down a little. Any ideas. Everything's tight. Maybe suspension settling? I
Any input is great
RogueKJ is offline
post #2 of 8 Old 06-07-2013, 06:36 AM
02libbyfirstcar
2002 KJ Liberty
Any input is great
Are you running stock UCA's? If so they could be hitting against the spring
02libbyfirstcar is offline
post #3 of 8 Old 06-07-2013, 08:01 AM
streetglideok
2005 KJ Liberty
Not to mention you're likely getting coil bind now. Only way to prevent that would be to put longer bump stops in front, but at the cost of reduced travel. Lots of issues with daystars all over this board.
streetglideok is offline
post #4 of 8 Old 06-07-2013, 08:19 AM
tommudd
2004 KJ Liberty
It could be a number of things
Longer bumpstops help
BUT main issue is the Daystar lift combined with weak stock coils and shocks.
The suspension already weak now works even harder which creates more problems .
I wouldn't think you'd have UCA/springs contact since it shouldn't be that high
Also how did the alignment come out? Did they get it close ?
Did you tighten the sway bar links AFTER full weight was on the ground ?
Forget if I asked you that before but think I did
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
05 KJ
tommudd is offline
post #5 of 8 Old 06-07-2013, 12:25 PM Thread Starter
RogueKJ
2004 KJ Liberty
Alignment near perfect. Brand new coils. Sway bars tightened with full weight of the jeep on the ground
And yes stock upper control arms
RogueKJ is offline
post #6 of 8 Old 06-14-2013, 10:56 AM
Spike6901
My lifted KJ's "bang" came from the struts topping out.
'17 JKU: Lift, Armor, 33's, more...
'14 WK2: Stock for now
'97 ZJ: Lift, exhaust, 31's, more...
Spike6901 is offline
post #7 of 8 Old 06-14-2013, 11:01 AM
tommudd
2004 KJ Liberty
Had it too high or using a spacer lift will do that
MUDD'S MOTORSPORTS
05 KJ
tommudd is offline
post #8 of 8 Old 06-14-2013, 12:26 PM Thread Starter
RogueKJ
2004 KJ Liberty
Found the noise an fixed it an order new lower ball joint since both boots are tore open
RogueKJ is offline
