-   KJ Liberty Forum (http://www.jeepforum.com/forum/f28/)
-   -   lifted now getting banging noise (http://www.jeepforum.com/forum/f28/lifted-now-getting-banging-noise-1533345/)
RogueKJ 06-06-2013 10:20 PM
Just lifted 04 liberty 2.5 day star brand new Moog coils. Getting banging noise in front over bumps. Driver tire rod has a little play in it. Front axles I can move by hand up an down a little. Any ideas. Everything's tight. Maybe suspension settling? I
Any input is great
02libbyfirstcar 06-07-2013 06:36 AM
Any input is great
Are you running stock UCA's? If so they could be hitting against the spring
streetglideok 06-07-2013 08:01 AM
Not to mention you're likely getting coil bind now. Only way to prevent that would be to put longer bump stops in front, but at the cost of reduced travel. Lots of issues with daystars all over this board.
tommudd 06-07-2013 08:19 AM
It could be a number of things
Longer bumpstops help
BUT main issue is the Daystar lift combined with weak stock coils and shocks.
The suspension already weak now works even harder which creates more problems .
I wouldn't think you'd have UCA/springs contact since it shouldn't be that high
Also how did the alignment come out? Did they get it close ?
Did you tighten the sway bar links AFTER full weight was on the ground ?
Forget if I asked you that before but think I did
RogueKJ 06-07-2013 12:25 PM
Alignment near perfect. Brand new coils. Sway bars tightened with full weight of the jeep on the ground
And yes stock upper control arms
Spike6901 06-14-2013 10:56 AM
My lifted KJ's "bang" came from the struts topping out.
tommudd 06-14-2013 11:01 AM
Had it too high or using a spacer lift will do that
RogueKJ 06-14-2013 12:26 PM
Found the noise an fixed it an order new lower ball joint since both boots are tore open
The time now is 12:11 AM.
