Lifted KJ fuel mileage - JeepForum.com
post #1 of 5 Old 06-16-2017, 05:14 PM Thread Starter
skippy102595
Just wondering what kind of MPG I should be getting running 245/70/R17's? Jeep has a 2.5" lift and looking back i didn't realize I mounted the largest size tire I could fit on a 2.5" lift until afterwards. I didn't realize that a 245/70/R16 is 1" shorter than a 245/70/R17. That being said, the tires aren't overly aggressive they are trail guide A/P's but i'm currently averaging 14mpg and that's mostly because the mpg is terrible when driving around town. It does fine on the highway as far as MPG goes. Also seems like it lacks a bit of power at the top end of each gear. Would regearing be helpful and if so what should i go with? It's a 06' 3.7L.
skippy102595 is offline
post #2 of 5 Old 06-17-2017, 10:05 AM
tommudd
2004 KJ Liberty
My 04 with 265-75-16s / over 4 inches of lift / 4.10 gears and lots of weight got 21-22 on the highway easily at 75 plus MPH
My 03 with 265-70-16s and 2.5 inches of lift plus 4.10s gets about 20.5 to 21 on the highway again at 73-75 MPH
Gearing is key for a tire that large , well anything much over a 30 inch, the 3.7s have a fairly narrow power band, drop a bit below with larger tires and stock gearing and the mileage is going to take a dump, transmission runs hotter etc
So now you have effectively lowered the gearing from 3.73 to about 3.50 and to gain back to stock type gear ratios need to go to a 3.93 ( which 4.10s would work great )
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
tommudd is offline
post #3 of 5 Old 06-17-2017, 10:20 AM Thread Starter
skippy102595
Thanks Tom. Like I said, highways not a problem it's the low gears stop and go at lights where i'm pretty certain a hummer h1 would be more fuel efficient lol hopefully 4.10s would help that as well
post #4 of 5 Old 06-17-2017, 10:56 AM Thread Starter
skippy102595
Also what kinda donor vehicles could i be looking for? Would a CRD have the parts I need?
post #5 of 5 Old 06-19-2017, 03:38 PM
tommudd
2004 KJ Liberty
Only the 4 cylinders
MUDD'S MOTORSPORTS
tommudd is offline
